| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
The Tamiya VW New Beetle kit has male rims. Does anyone know what aftermarket rims would look nice, and are also MALE rims? So far, all the aftermarket rims i have are Female.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
With a quick use of the "search function" I found this. It will probly help
http://www.automotiveforums.com/vbul...ghlight=female |
Why don't you convert them?
You could use styrene that will fit or you could use the pegs from the bettle wheels.
I want to build models again :' ( |
i saw that post before. I read it wrong. I thought it was male to female.
It's pretty hard to find aftermarket male wheels. Tamiya seem to be the only manufacturer to use the male wheels. Hasegawa have male wheels on their kits, but their aftermarket sets are female like Fujimi's.
I think you have a couple of options: 1) Utilise a set of wheels from another Tamiya kit. 2) Carry out a conversion. |
Some of the Aoshima kits come with male wheels, I have two Chasers and they both came with males, not sure if their aftermarket stuff has both though ?
imagine my problem. im looking for aftermarket wheels for my lotus 7. the fronts are male (with a little pin thing) and the rears are female.
whatever set i get i will have to modify them. it will be fun though
Here is a photo of my in progress new Beetle with aftermarket wheels (Fujimi).
![]() To adapt those wheels i have to file down the front of the rotors a little bit and cut the back of the rotors to move them inside the fenders. The poly caps that go inside the rotors are to be trimed to fit the new space inside the rotors. Also, I file down more or less half of the center section of the wheel where the poly cap go. The poly cap was cut by the half also. Then I use 2mm styrene rod to install the wheels. Even cutting the poly caps by the half they hold the wheels very well. If you do not made this modifications the wheels are going to be stiking out too much.
![]() Current projects: , 49 Merc (100%), 99 Celica (100%), 72 Corolla (100%), Lexus IS 300 (100%) NEED MORE PROJECTS! |
thats the look im going for. I'd lik some Model5's, but Im prolly gonna end up using the BBS wheels from my 300ZX
