Old 06-26-2003, 03:40 AM
TURBOSATURN's Avatar
TURBOSATURN TURBOSATURN is offline
Painting
Currently my girlfriend is working on a model, and she just started spraying the body, now i went through all the procedures with her and everything, but i've noticed that, even after letting the car dry for multiple days, the body is sticky like the paint is still wet. She didn't put on think coats just light mists' is this normal?
Old 06-26-2003, 03:44 AM
Dublinguy's Avatar
Dublinguy Dublinguy is offline
Turbosaturn,
All depends on the type of paint that was used. If it is enamel it will take some time to dry fully, like a week or two. Also you may not have been leaving enough time between the coats to allow it too dry properly. First question to answer is what paint are you using?
Ciaran
Old 06-26-2003, 03:46 AM
Its model master enamel and we waited about 3 hours between coats.
Old 06-26-2003, 03:51 AM
Dublinguy's Avatar
Turbosaturn,
I think you might need to leave the coats longer, although when I have used enamel I didnt but it just means that the last coat will take even longer to dry. I have noticed it can take 3 to 4 weeks for Enamel to dry and cure properly and even then it can still be soft. I believe there is something called Enamel Hardener that can be bought in Car shops that when added to the paint helps to dry it quicker and obviously harden the paint more.
Ciaran
Old 06-26-2003, 03:54 AM
But how would i go about applying the hardener, when im spraying from a can?
Old 06-26-2003, 03:57 AM
Dublinguy's Avatar
The only way to add the hardener would be to airbrush the enamel rather then use a spay can.
Ciaran
Old 06-26-2003, 03:58 AM
So in other words im stuck waiting for it to dry?
Old 06-26-2003, 04:04 AM
Dublinguy's Avatar
Unfortunately yes...thats the joys of using Enamel for the body...sorry
Ciaran
Old 06-26-2003, 04:47 AM
So what kind of paint does everyone one else use from rattle cans?
Old 06-26-2003, 04:55 AM
Dublinguy's Avatar
Tamiya TS range dries very quickly you can re-cost in about 10 to 15 minutes and should be cured in about a week. Any Lacquer based paint wil dry quickly but you must be careful as these paints are referred too as 'Hot' paint. So you must make sure that you primer all parts that will be covered in the lacquer. Some guys use automotive paints because you can get an exact match for the car that you are modelling but again a primer must be used before hand.
Ciaran
Old 06-26-2003, 07:01 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
I think it is best to leave the paint to dry, until the model doesn't smell like paint anymore, thats how I go about it and I haven't had any serious problems before. Most enamel paints I have used take about 1-2 weeks to dry.
Good luck!
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 06-26-2003, 02:32 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Where are you? Weather condiitons play a huge roll in drying time. For instance I am in Colorado and we have no humidity so my stuff dries fast, however somewhere near the ocean or some god awful swesty place like Fort Worth ( sorry all you Texans ) it will take forever. I know guys who use a food dehydrator to help speed the drying process
Old 06-26-2003, 02:35 PM
unfortunately im in Utah, so similar weather to you.
I told my girlfriend, and she got all mad, she anxious to get the model done!
Old 06-26-2003, 02:40 PM
dag65's Avatar
AH but patience is a virtue and a clean paint job is well worth the wait. But I hear where she is coming from, I have messed up many a paint job because I could not wait to handle it and put it all together.
I mostly use Auto Lacquers now so it dries faster
Old 06-26-2003, 04:40 PM
anodize7's Avatar
anodize7 anodize7 is offline
yeah yeah.... patience is important.... even the pro here think that patience is a very important aspect....
i used Tamiya spray can.... recommended i think
Projects :
Jaguar MK II Racing
HKS Skyline
ts paint over xf paint Bobj Car Modeling 2 09-25-2002 06:47 AM
Painting Models using Tamiya Paint GTRRR Car Modeling 3 08-25-2002 05:41 AM
For those using Tamiya spray paint for painting car body Ben L. Car Modeling 5 08-08-2002 04:53 PM
Paint Droplets on Hood from House Paint!! plkalra Exterior | bodykits | Lighting 4 05-03-2002 08:23 AM
Paint Paint Paint dscott Car Modeling 1 01-17-2002 02:22 PM
