Old 06-26-2003, 12:28 AM
blade34609's Avatar
blade34609 blade34609 is offline
Si Swap ?
Hi,
I have a 90 LX with the DPFI D15 engine.
I am going to swap a 90 CRX SI D16 engine into it.
Will I need a SI ECU or can I still use my LX ECU and just use FourthGenHatch's HOW TO INSTALL MPFI http://www.fourthgenhatch.com/mpfi.html
When reading it I read how it said if engine is out of car just swap DX harness over to SI?
What does it mean when you solder and heatshrink over to plug side and harness side?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 06-26-2003, 12:43 AM
blade34609's Avatar
Oh when it says switch your DX engine harness over to the SI engine it means to take out the SI engine wire harness and replace it correct?
So i wont need to do any wire extending. Just wire up the 4 wires that come from my ECU correct?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 06-26-2003, 01:06 AM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
yes i'm almost positive you need an si ecu or at least an ex ecu i would need one if i just put on mpfi onto my dx engine. your dx ecu just won't controll the multipoint fuel injection.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 06-26-2003, 01:08 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Take off the DX engine harness and put it on the Si/ZC means unplug all the plugs and wires off of the DX engine (same as LX engine by the way) and plug them onto the sensors and stuff onto the Si/ZC engine.
I'm not sure if you have to extend wires from going from DX > Si since they are SOHCs, but from DX > DOHC ZC I know I had to.
Plug side and harness side had do do when you cut a wire in half, the half of the wire stuck into the plug is the plug side, the half of the wire that goes to all the other bunch of wires is the harness side. I'm going to get a picture later on to better explain that.
And you do need new MPFI ECUs, it says that in my How-To.
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
ATT: Skyline240 or anyone doing the RB swap or anyone having info on the RB swap... dohctor_yaj 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 29 04-18-2003 09:55 AM
people who did the det swap or any swap - what did u do with the stock engine? jared240sx 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 09-19-2002 11:20 AM
Brake swap -is mandatory a Master Cyl swap? mmasse '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 05-25-2002 12:04 PM
Swap this Swap that..... white97ex Engineering/ Technical 8 01-19-2002 12:06 AM
