Old 06-25-2003, 04:31 PM
dash90 dash90 is offline
Angry GM fault codes
Has anyone ever experienced a 'blinking' parking brake light? Mine blinks a pattern of 8 short and one long. It starts as soon as I turn the key on. I've cycled the brake lever, still no dice. It's on an 89 C1500, 5.7 TBI, no ABS just standard disk/drums. Any ideas?
Old 06-28-2003, 11:37 PM
secretaznman69 secretaznman69 is offline
oh oh oh, i know! this happened on my 94 c1500 4.3 litre v6 .. Just take off the neg on the battery, and then replace it after 10 minutes, should be fine after that, its just a fault or something i believe... but nothing should be wrong... if all else fails, check your brakes and especially your brake fluid.... when mine came on it was after i changed the brakes, rotors, shoes, drums, and bled the lines... but its fine..
Old 10-03-2003, 04:03 PM
Erik_The_Red Erik_The_Red is offline
Send a message via ICQ to Erik_The_Red Send a message via AIM to Erik_The_Red Send a message via Yahoo to Erik_The_Red
Re: GM fault codes
That is only a temporary fix. Removing the battery resets the computer the problem still exists. I think that is is a brake sensor of some sort. I have been searching for a solution for this problem for the last few years. I have not replaced any brake sensors yet though.
fault codes G. Marquis grand Grand Marquis 2 03-01-2004 02:41 AM
Secondary Air Injection Fault Code camfambmw540 5 Series 1 05-30-2003 08:54 PM
Throttle Position Fault Code 1995superchargedm3 M3 0 12-21-2002 12:48 AM
Is O2 Sensor Fault Code 100% Correct? BETTER THAN A WRX Maintenance 12 06-10-2002 05:25 AM
bluebird engine fault code wanted zefire Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 02-11-2002 02:33 PM
