Old 06-24-2003, 10:45 PM
ajusaf ajusaf is offline
Need help my crx won't start at all, its not the battery.
its started a while back. If i recall correctly, I would crank make the noiseas far as cranking but never turned on and it did this at different times for a month or two, but towards the end i would turn the key and it never cranked or made a noise and usually after a few minutes it would finally start until one day boom doesn't start regarless i was going to try jump start it to see if it will run . I know the battery is good and fuses are all good inside and under the hood . is it the starter or ignition or something else?
Old 06-24-2003, 11:03 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
starter is the first thing to check if you know your battery is good and fully charged, after that double check the fuses and wires to everything.
Old 06-25-2003, 12:49 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Check the relays and shit.
Old 06-25-2003, 04:24 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
main relay ?
Team Lonely Drivers
Old 06-25-2003, 06:36 AM
relays? you mean the bigger fuses that are like a box looking thing inside the fuse box under the hood? where is the starter located on the car? anyway to make sure is the starter and not the ignition or vice versa?
Old 06-25-2003, 07:24 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Hit the starter a couple times with a bar or something.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 06-25-2003, 07:25 AM
cyberrexer's Avatar
cyberrexer cyberrexer is offline
Send a message via AIM to cyberrexer
Look at the Main Relay & Ignitor items on this website....
http://www.marklamond.co.uk/howto/el...electrical.htm
1991 CRX siR
1991 CR-X Si
1993 UK 2.2 4WS - FOR SALE
2005 Lexus IS200 - SOLD
1990 MX-5
Old 06-25-2003, 07:30 AM
where is the starter located at?
Old 06-25-2003, 07:31 AM
turbcivic's Avatar
Above the tranny towards the back side on the other side of the dist.
Old 06-25-2003, 07:33 AM
is there a pic of it not use to honda starters
Old 06-25-2003, 07:46 AM
turbcivic's Avatar
it is back in here.
Old 06-25-2003, 09:03 AM
91civicDXdude's Avatar
nice pic. i wonder who it belongs to
Old 06-25-2003, 10:09 AM
turbcivic's Avatar
No idea
Clean swap, how hard was it and what other parts did you need. Planning on doing the same thing but with a built enigne and 100 shot for fun.
Old 06-25-2003, 10:17 AM
not meaning to steal the original thread,
but the installation was very easy, i used HCP mounts, it bolted right in. since i already had converted to MPFI and the engine is OBD0 B18A1, 95% of the wiring was the same. i had to extend a couple sensor wires, that was it. the axles were directly bolted in to my DX hubs, so no changing there, however i had to remove a small metal dust ring on the inside of the hub or it made the axles bind.
parts i needed were mount kit, motor, ecu, tranny, i welded my own shift linkages to save some money, and then various sensors that were broken or needed replacing. plus i did basic overhaul shit like plugs, plug wires, distributor cap things like that.
Old 06-25-2003, 10:22 AM
turbcivic's Avatar
That is what i like to hear. I rode in my friends 5 gen hatch with a b18a and my friends crx with a GSR and there was something about the b18a that i liked.
No start - but its not the alternator, battery or starter (?) APillowOfClouds Corolla/Matrix/Voltz 3 07-28-2008 07:55 PM
Need Help!! Car won't start hondaguy26 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 24 08-06-2005 12:37 PM
Need help. Car won't start Damarr30 Fiero 12 10-03-2004 03:15 PM
Desparately Need HELP, Car won't start. BulletTooth 3 Series 0 03-07-2004 01:28 PM
HELP! Car won't start and its not even cold! skyllz Off-Topic 3 02-29-2004 02:59 PM
