Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-27-2008, 07:28 PM
APillowOfClouds APillowOfClouds is offline
No start - but its not the alternator, battery or starter (?)
Hi All,
I have a 99 Corolla. A couple months back, I was having a problem where the car would not start, would just click, but repeated start attempts were successful eventually. Changed the battery initially since it had never been changed and I could do it myself. Turned out to be the starter, had that changed and car had been fine for about 2 months.
On Friday, I drove the car to work, did not notice any issues. Went to drive home for lunch, and battery was totally dead. Got a jump from one of those battery charger boxes, and drove it home. Still would not start again once I turned it off at home.
Jumped the car later that evening and let it run for about 20 minutes - it eventually stalled. At this point, since the battery is new, I figured, ah-hah, must be the alternator. Picked up a new (well, reman) alternator and installed it. Jumped the car, ran for 30 minutes, turned it off, tried to start, battery was still almost totally dead (got a warning light and the door chime tried to sound). Jumped it again and it stalled again after 15-20 mins.
Come this morning, I jumped it and as soon as I disconnected the jumper wires it stopped. Tried it twice. It just cuts out as soon as I take the cable away.
Had the battery tested, battery is definitely still fine.
Any ideas? I would be VERY VERY appreciative at this point!
TIA
Rob
Old 07-28-2008, 08:35 AM
GSS123 GSS123 is offline
Re: No start - but its not the alternator, battery or starter (?)
When the car is connected by jumpers to another it works. When disconnected it stops. So my guess is the other car is acting as your ground. Check battery connections to your car at both the battery and at the other end. I believe your ground cable is not properly grounded to the car.
Old 07-28-2008, 09:34 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'll agree with GS on checking the ground as well as the battery cables for good contact and free of corrosion. Acid-damaged cables can look better than they really are.
Nowhere in there did I see an attempt to recharge the battery using a plug in charger. Running the car alternator for 30 minutes is not enough to give a dead battery a good full charge after depletion, not to mention a waste of gas. For $30-$40 you can find a decent charger that you can leave on overnight. For really depleted batteries, I prefer to slow charge them to minimize heating and vaporization of the water inside, which brings me to my next suggestion.
If it is not a sealed or maintenance-free battery, check the acid level and use distilled water to bring the levels up to at least cover the plates you can see inside. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-28-2008, 07:55 PM
Thanks for the replies! Problem turned out to be something simple and dumb - Autozone sold me a dead remanufactured alternator. Failed 3 tests at 2 different stores. Got one that passed, car now works....
