Old 06-23-2003, 04:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
code 15
ok so i tried to start up my car today and my ecu is flashing 15 times, which is a code 15, ignition ouput signal
anyone know how to fix it or whats wrong exactly ?
Team Lonely Drivers
Old 06-23-2003, 04:08 PM
LEXUSLEO LEXUSLEO is offline
code 13
Does anyone know what code 13 means.....?
Old 06-23-2003, 04:25 PM
joeyo joeyo is offline
Send a message via ICQ to joeyo Send a message via MSN to joeyo
I'm not sure if these are valid or not but have a look at
http://www.crxworld.de/ecucodes.html
Joey
Old 06-23-2003, 04:48 PM
fuck his code 13 lol thats and easy fix
how do i fix my code 15?
Team Lonely Drivers
Old 06-23-2003, 05:18 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Ignitor, easy fix. costs about 45 bucks
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 06-25-2003, 03:51 AM
yeah i got it narrowed down to either my coil or my igniter. what 45, i got a quote from napa for $109, where did u get yours from ?
Team Lonely Drivers
Old 06-25-2003, 06:53 AM
turbcivic's Avatar
emp discount through Honda
Old 06-25-2003, 06:56 AM
turbcivic's Avatar
I would place money on the ignitor. A code gets sent to the computer by the ignitor because the comp controls it. The ingtion coil is controlled by the ignitor so a code won't get sent. When my ignitor went out, it sent a code but when by coil went out it didn't.
By the way, go to honda and have them pull the service bulletin for the ignitor. Don't know if yours was done buty i belive if it wasn't, the ignitor should be black. The ones honda replaced them with were brown.
Old 06-25-2003, 12:26 PM
the igniter is brown, or the one i pulled was brown, and even my stock d15 igniter was brown.
heres the curious part, so i tried to start it using the stock integra igniter but it didnt work, so i pulled it and stuck my civic igniter in there and it still didnt work. thats why im kinda thinking its not the igniter but the symptoms point to an ignitor. im at a lost here.
oh and heres the thing, it did work the first time i tired to start it, the coil was going and everything. but one time it just stopped working
Team Lonely Drivers
Old 06-25-2003, 12:44 PM
turbcivic's Avatar
did you test the dizzy
Old 06-25-2003, 01:17 PM
i just found out i dont got continuity between the white wire and the ground, the white wire coming off the ignitor, anyone know anything about that and how to fix it ?
Team Lonely Drivers
Old 06-25-2003, 03:13 PM
can anybody tell me where that white wire runs too after the dizyy toward the ecu
Team Lonely Drivers
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
'98 Blazer - Codes, codes, codes! MAF & O2 LAN2UNOW Problem Diagnosis 3 03-02-2008 08:56 PM
codes,codes,codes vdubdad Beetle - New/New Beetle Convertible 0 10-22-2007 08:33 PM
Codes, codes, codes.... alkemist Riviera 7 06-19-2006 06:52 AM
Codes, Codes, CODES!!! patrickkdunn Contour 8 05-01-2004 04:31 PM
