Go Back   Automotive Forums Car Chat > Mercury > General Discussion
Old 06-22-2003, 08:57 PM
DennisHershey DennisHershey is offline
Brake Light Problem
HELP!
I have a 1996 Mercury Mystique whose brake lights (including the high centered mounted one) will not go off at any time even after the key is out of the ignition. The car ahas an after market alarm system and I was wondering if that had anything to due with the problem. How do I repair this ?
Thank you,
Dennis Hershey
Old 06-29-2003, 07:44 PM
V-8Fan V-8Fan is offline
Dennis, a question, followed by a general suggestion: Did this problem crop up when the alarm system was installed? If so, I would double-check the installation.
Otherwise, I would remove the fuse which normally would provide power for the light circuit in question. If the lights extinguish, you then know the problem is in the brake light circuit itself...and I would take a close look at the brake light switch in that case.
Hope this helps!
-AW-
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
