Old 06-21-2003, 12:21 AM
hilltopper hilltopper is offline
Sun Roof leak?
This morning after a heavy raid, went to back out of my drive way, as i hit the curb, a whole bunch of water splashed on me from the sun roof opening in the roof(where the shade goes back). What do ya guys think the problem is, btw i have a 90 si :P.
Old 06-21-2003, 01:29 AM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
i had the same problem man, take out your back tailights and you will see some rubber hosing exiting into the back wheel well on each side. more than likly they are clogged up. it took me 6 months to find it but after i un clogged them and took of a filter type device that is attached to the hose my sunroof hasnt leaked since and you can also check your drain holes at the top of the sunrrof
Old 06-21-2003, 10:12 AM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
NO SHIT!!!!My damn sunroof has leaked since i bought the car...i didnt know there was a drain for it! I haveto park with the front of the car down hill or I end up with a waterfall on my head when i put on the brakes
Honda...An Army Of One
Old 06-21-2003, 05:48 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
There's actually 4 drain hoses on the Si sunroof, One for each corner. The two rear ones exit right past the taillights, behind the rear wheels. And the two fronts come down inside the A-pillars past your feet and exit behind the front wheels.
To check to see if you're clogged, just dump some H20 in the sunroof track in each corner. Obviously, it should come out on the ground, not in the car.
Have Fun
There's nary an animal alive that can outrun a greased Scotsman!
Old 06-21-2003, 08:41 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
you can blow compressed air down the 4 drain tubes to clean them out, we do it at work alot...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 06-21-2003, 10:38 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
happened to me too, I replaced my headliner as well. My tubes were clogged in the rear, waterfall!
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 06-22-2003, 12:55 PM
plkelley's Avatar
this thread makes me happy!
Old 06-22-2003, 10:15 PM
Well thanks for the advice, heheh hopefully ill get a chance to fix it soon :P. Whats the easyest way at getting to the drain tubes ?
Old 06-22-2003, 10:21 PM
take out your rear tail lights and you will see them
Old 06-22-2003, 10:27 PM
You should be able to get at them without taking out the tails, just pop out those plastic pieces. I think the ones in the front are under the fender liner
Old 06-22-2003, 10:45 PM
NIce, now i just need some dry weather and im all set, thanks for the help.
Old 06-22-2003, 10:51 PM
Old 06-23-2003, 07:06 AM
91EF3ZC's Avatar
AF Premium User
also check the outlet behind the rear wheel, under the bumper cover. mine were clogged there. it's like a rubber nipple looking thing.
Sun Roof Leak? 1nell Villager 0 01-11-2008 03:43 PM
Sun Roof Leaks rusty-xterra Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 03-03-2007 09:28 PM
Sun Roof Leak Peter99 Expedition 1 04-25-2006 07:10 AM
Sun roof leaking justkilintyme Engineering/ Technical 3 08-16-2003 02:06 PM
