Old 06-19-2003, 07:04 PM
justkilintyme justkilintyme is offline
Sun roof leaking
Anyone know how to repair a leaking sunroof? Can a new seal be purchased, or is it all one unit?
96 Civic ex
Old 07-17-2003, 12:20 PM
sp3cial_bl3nd's Avatar
sp3cial_bl3nd sp3cial_bl3nd is offline
Send a message via AIM to sp3cial_bl3nd
my sis had the same problem, and it ended up costin like a grand to fix because nobody likes to bother with them....
Old 08-03-2003, 01:10 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Where does it Leak?
Does the roof look like its closing properly?
If it is I'd check the drains first. Try this, open the sunroof and pour a half a cup of water in each corner of the sunroof. The water should drain out to the corners of the car (usually behind the wheels). The front ones are easy to clear with some compressed air or something, clearing the rears require the sunroof to be removed. If the drains look good you can take the headliner off and have a look at the rest of the sunroof, you might have a rust hole in the frame or something. (the helms manual is great help here). You'll need a helper, some patience and common sense but it's the best way to see where the leak is coming from.
Old 08-16-2003, 02:06 PM
Hyatus Hyatus is offline
Banned
sometimes the resivour for the sunroof gets blocked......that might be it ......just pop out your headliner to check it real quick i did that when my leaked and unclogged the plug and it worked it saved me major bucks!!!!
Sun Roof Leak? 1nell Villager 0 01-11-2008 03:43 PM
Sun Roof Leaks rusty-xterra Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 03-03-2007 09:28 PM
Sun Roof Leak Peter99 Expedition 1 04-25-2006 07:10 AM
Sun Roof leak? hilltopper '88 - '91 Civic | CRX | Wagon | Shuttlee 12 06-23-2003 07:06 AM
