Old 06-18-2003, 09:49 PM
blade34609's Avatar
blade34609 blade34609 is offline
What should I run with D15?
Hi,
I am heading off to the track friday to run it in the 1/4 mile.
I have a 90 Civic LX 4 door with the D15.
I have a short ram intake and GT spec muffler.
I am a pretty good driver with stick tranny.
What do u think I should run the 1/4 mile in?
Or what should I expect to run?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 06-18-2003, 09:51 PM
91civicDXdude's Avatar
17.0
Old 06-18-2003, 09:54 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Low 17s if you are good. Nothing sort of a MPFI will ever make the D15 fast.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-18-2003, 10:00 PM
blade34609's Avatar
Ok, guys that what I thought I would run.
If I was to convert to MPFI what would I run then and also how much hp increase would I get?
Is it easy to convert it to MPFI, I have read how to do it and the ECU seems kinda complicated.
Also, If I was to get the SI ECU can I get one off of Ebay for 20 bucks its supposed to be a modifed 88-91 Civic SI ecu. WIll it work?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 06-18-2003, 10:15 PM
03 si-lent 03 si-lent is offline
Send a message via AIM to 03 si-lent Send a message via Yahoo to 03 si-lent
IF YOUR LOOKING FOR MODERATE POWER AND GREAT BANG 4 YOU BUCK GO WITH THE ZC SWAP ... THE ONLY PROBLEM IS WITH THE INJECTORS , YOU HAVE TO SWITCH THEM TO THE MULTI PORT AND GET A 88 INTEG ECU BUT AFTER THAT YOU WOULD BE LIKE HIGH 15'S LOW 16'S
Only runs with key in the START position AMAMEK9 Eclipse Problem Diagnosis 6 03-12-2011 07:47 PM
what should i be able to run at the track with the following mods? blksrt4_2005 SRT4 14 08-10-2010 01:26 AM
What should I expect to run in a stock ls-vtec? And also a cr-vtec? sheemo3 Engineering/ Technical 0 09-08-2003 03:29 PM
what should my car be running in the 1/4 teaminvasion Integra 22 09-02-2003 10:19 PM
89 Crx w/ b16 + cable tranny? what should i run? Crixer '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-06-2002 10:18 AM
