Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 08-29-2007, 01:15 AM
blksrt4_2005 blksrt4_2005 is offline
what should i be able to run at the track with the following mods?
1)agp wastegate 18psi dropping down to 15
2)gutted cat
3)mopar intake
4)motor mounts inserts
5)mopar bov
6)ngk iridiums
i live in arizona.....so its pretty damn hot...lol....but what should i be able to run on street tires???..
im planning to go to the track this weekend so i want to get an idea of whats the times i can run....what should i launch at??
Old 08-29-2007, 03:06 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: what should i be able to run at the track with the following mods?
Low 13's
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-29-2007, 11:38 PM
what should i launch at???
Old 08-30-2007, 11:16 PM
Turbodog97's Avatar
Just a Neon
2k rpms
05 Srt4
97 Mx-5
Old 09-02-2007, 07:50 PM
well finally i went to the track last night and after 4 runs i ran a 13.8... but than i couldnt run better than that......ii had no traction till the end of second gear....im planning to buy some drag radials for better traction....do you know which drag radials are pretty good????
Old 09-03-2007, 12:06 AM
Turbodog97's Avatar
Just a Neon
That's alright...what is your trap?
05 Srt4
97 Mx-5
Old 09-03-2007, 04:56 PM
98mph
Old 09-03-2007, 06:05 PM
Turbodog97's Avatar
Just a Neon
That's kind of a low trap for what you ran...you should be around 103 or so...
05 Srt4
97 Mx-5
Old 09-03-2007, 09:09 PM
nah it was 98.....ill try to post up the slip
Old 09-08-2007, 05:30 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
2)gutted cat
3)mopar intake
5)mopar bov
6)ngk iridiums
do motor mount inserts really a big diffrence???
http://www.cardomain.com/ride/2865492
-AEM short ram
-XO2 racing intercooler
-GReddy blow off valve
-Injen downpipe (spits flames!...runs a little rich...lol)
-SAMCO piping
-Mopar stage 2 kit(injectors, ecu, wastgate...)
-KOYO perofrmance radiator
-TIEN lowering springs
-18 inch r2 rims(i dont use these for the track...)
-stage 2 Clutchmaster
-XO2 short shifter
-XO2 oil cooler
-removed 2 resinators
Old 09-08-2007, 08:08 PM
yeah....much better than stock....you get rid of alot of wheel hop...
Old 09-09-2007, 01:11 AM
Turbodog97's Avatar
Just a Neon
Get some solid mm's instead...you'll eventually make the transition...better start early than late.
05 Srt4
97 Mx-5
Old 09-09-2007, 05:41 AM
MrCrazy's Avatar
sooo could that really be the problem with my wheel chattering bs endless?
-AEM short ram
-SAMCO piping
-XO2 short shifter
-XO2 oil cooler
Old 08-10-2010, 01:23 AM
slabb ridder 01 slabb ridder 01 is offline
WELL IM NOT A VERY GOOD DRIVER AND I WENT 13.2 WITH FULL STAGE2 W//T IN 1KMILE 04 SRT4 WITH A 2.0 60FT AND MISSIN THIRD ON STREET TIRES. OH DID I MENTION I HAVE A DWN PIPE,CATBACK EHAUST,TIEN COIL OVERS.AGP WASTEGATE.MOPAR COLD AIR INTAKE.KN AIR FILTER AND NGK 1STEP COLDER PLUGS. MSD 8.5 WIRES WITH NO TUNE ON PUMP GAS.
Old 08-10-2010, 01:26 AM
Let me know wha you think about that
