Old 06-17-2003, 10:22 AM
NinjaPoweredAccord's Avatar
NinjaPoweredAccord NinjaPoweredAccord is offline
Send a message via AIM to NinjaPoweredAccord
Need help with 1990 Accord
The other day I was messing with the lighting on my 90 Accord Coupe. It’s an auto (freakin A, I know) and I was trying to make the lighting on the gearshift selector look a brighter shade of blue, as opposed to the green/blue that it is now. While I was doing this I broke original bulb. It has no readable part number on it, and I can’t find it online. Does anyone have a suggestion as to where I can look?
Old 06-17-2003, 04:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
are you talking bout the light in your dash, or actually by the shifter?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-17-2003, 08:18 PM
knorsk knorsk is offline
go to pep boys or an auto store...they usually have full detail honda manuals on shelves. In the index look up lights/lighting they should have the part number listed for the bulb you blew up. Probably only costs 1.99 and they should have it in stock.
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
Old 06-17-2003, 09:59 PM
96 ex-r 96 ex-r is offline
check out www hondaautomotiveparts.com is a good site to check out parts and stuff...
Old 06-19-2003, 01:11 AM
Ok I think I found the bulb, but what if I don't want the OEM bulb? I'd love to talk to someone who understands electricity better than I do, because I need to make this light brighter!
Old 06-19-2003, 02:25 AM
b16a3sol b16a3sol is offline
if you want a brighter bulb than the one you have now, just get a bulb that is rated with a higher wattage. dont go too high, or you will draw too much current and possible burn out the wiring too the bulb, if the fuse doesnt blow first. you also may end up making some of the other lighting wired with it a little dimmer.
your other bet is to just run new wiring to the spot and put a brighter bulb in that is drawing power from a new source.
the final solution would be to change out the piece of plastic that the light is shining through to the desired color.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 06-19-2003, 09:39 AM
micheal micheal is offline
Send a message via AIM to micheal
or simply buy proclaimed "high wattage " bulbs.
some do look and burn actually brighter
Old 06-19-2003, 10:39 AM
I am beginning to see that I have two options:[list=1][*]Run new wires to a new bulb, which would be a big pain for the small change that would result[*]Find a bulb with a higher rated wattage[/list=1]I guess now I have a new question:
  • Is there a website somewhere that sells really obscure bulbs?
See, the thing is, this is just a small little bulb that no one else would ever mess with. Where can I look for one rated at a higher wattage?
need help with 1990 integra b20b swap mexichuy1 JDM Motor & Parts info/chat 1 10-03-2006 06:51 PM
Need help with 1990 Sable i hate my car Sable 2 06-21-2005 08:39 PM
Need help with 86 Accord LilBitEG Accord/TSX/Accord Hybrid 1 12-30-2004 09:18 PM
Need help with 1990 300zx 2+2 N/A questionablethreat 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 01-22-2004 05:12 PM
HELP! need help with 1990 door latch assembly! IXLR8TL3.2 Accord/TSX/Accord Hybrid 1 10-28-2002 10:37 AM
