Old 06-17-2003, 01:18 AM
BellsRanger BellsRanger is offline
D16Z6 swap into my 91 SE questions?
I am putting a d16Z6 into my 91 SE and I have couple questions. If I get the whole D16z6 setup including intake, distributor, wiring harness, and ECU will it require any additional wiring or do I just plug it in? Will this engine bolt right in with all these parts.....will I need to modify any mounts or the harness? I think my car only has two injectors in its intake setup but if I take it all out will I have to consider anything else? My engine now is the 1.5L SE motor.
Thanks, I appreciate the feedback
Ranger
Old 06-17-2003, 10:15 AM
ttt
Old 06-17-2003, 10:27 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Maybe I'm stupid, but what the heck is an SE? Do you have the Special Edition civic? If so, is that the same thing as the DX or EX? I might be able to help you if I knew.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-17-2003, 11:12 AM
It has a 1.5L so I am pretty sure it is the same as the DX just with SI body moldings. It looks like an SI but its really a DX. The intake system looks a little different to me....I think it only has two inectors but I am not sure.
Thanks
MG
Old 06-17-2003, 11:25 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
yea im with him, I have never heard of an SE, you have any pics of your car? if not, does your engine look like this?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 06-17-2003, 11:28 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Tony, you cant link from geocities
Click here to see the picture though.
http://www.geocities.com/twistedride...tsc_engine.jpg
Old 06-17-2003, 11:31 AM
Tony's Avatar
TLD Member #1
well damn it, when did they start that up, i used to be able to. Thanks though
Tony
Old 06-17-2003, 11:50 AM
This is the closest picture I could find that looks similar to my engine. It looks the same as most 1.5L motors but the intake system is different as you can see. I dont know if it has anything to do with it, but I live in Canada so maby the SE is only up here???
Thanks for your help,
Old 06-17-2003, 11:54 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
yup ... thats a dx. Dual Point Fuel injection.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-17-2003, 11:56 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
SE=canadian. we actually had this discussion not too long ago (pay attention TONY )
i do believe you are pretty much correct. go to www.4thGenerationCivic.com and look in the engine section. there are several links that should be able to help with the z6 swap.
Q: I get the whole D16z6 setup including intake, distributor, wiring harness, and ECU will it require any additional wiring or do I just plug it in?
A: if it is the stock d16z6 harness then yes. you will need a conversion (jumper) harness. will cost around $150. with that you will only need to extend and run 8 wires...4 going to the o2 sensor, so it's pretty easy. e-mail jason at: [email protected] (yikes, i hope that is still it)
Q: Will this engine bolt right in with all these parts.....will I need to modify any mounts or the harness?
A: the engine will bolt right in. you do not need to modify to mounts. with the conversion harness mentioned above, there is no need to modify to stock harness
Q: I think my car only has two injectors in its intake setup but if I take it all out will I have to consider anything else?
A: the 2 injectors is the dual point set-up. when you swap in the z6 you will have to do a MPFI conversion. for basic info you can read
http://www.4thgenerationcivic.com/ho...conversion.htm you should refer to the links in the engine section (as mentioned above) for how to MPFI using the z6 parts.
what is the engine code stamped on the block?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 06-17-2003, 12:01 PM
Excellent, Thanks for your help.
amy@af's Avatar
never a problem
Old 06-17-2003, 12:13 PM
I do have one more question to clarify. If I buy the wiring adapter you recomended, all I would do is plug in the 5G ecu and wiring harness and this adapter will take care of the rest or will I still have to rewire my DPFI setup?
So it would go ECU to 4G internal harness to adapter to 5G harness?
Old 06-17-2003, 12:30 PM
amy@af's Avatar
you will still need to rewire MPFI. that is a whole seperate ball of wax from running a new ecu.
that is what it looks like. 1 side plugs into your stock harness, the other side into the p28 ecu (d16z6).
Old 06-17-2003, 12:44 PM
Tony's Avatar
TLD Member #1
alright, ill go crawl back in my little cave and shut up
I thought I remembered something about Special Edition, but wasn't paying attention.
Tony
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
D16z6 swap into 91 hb chivid '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-13-2006 09:57 PM
D16Z6 swap into 92 civic VX rallyway '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-24-2005 05:32 PM
D16Z6 swap into 1989 Civic Si Palozzi '88 - '91 Civic | CRX | Wagon | Shuttlee 7 08-04-2004 12:00 PM
D16Z6 swap into the 4g4d bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-25-2003 01:17 PM
