Old 06-11-2003, 02:39 PM
jeffsgotaciv98 jeffsgotaciv98 is offline
Send a message via AIM to jeffsgotaciv98
Got an idea
I have seen this on real cars...but you guys have any ideas on how to make a clear hood. Haven't seen this done yet and thought it would be unique. Please post any ideas, both pros and cons, thanks guys. I want to put a clear hood on my Revell Civic SI.
Old 06-11-2003, 02:41 PM
lowcrome's Avatar
lowcrome lowcrome is offline
Send a message via AIM to lowcrome Send a message via Yahoo to lowcrome
clear resin
Old 06-11-2003, 02:42 PM
I have never heard of clear resin, can I just lay it over the original hood to get the design right?
Old 06-11-2003, 02:43 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
clear styrene rested on the original hood then heated so that it will go to the rite shape...should work
-Andrew-
Old 06-11-2003, 02:44 PM
lowcrome's Avatar
the easy way would be to make a mold of the original hood
then use some kinda clear resin
rcmaxx rcmaxx is offline
some fujimi models come with clear hoods.
Old 06-11-2003, 02:45 PM
lowcrome's Avatar
if u want it clear hood u could always put no hood on
Old 06-11-2003, 02:48 PM
Were can I get clear styrene, I have never seen it before. And were can I get clear resin to put in the mold. I guess I could heat the styrene around the hood for the mold, then pour in the clear resin? How does that sound?
Old 06-11-2003, 02:55 PM
that might not work very well, you are better off using some sort of clay.
Old 06-11-2003, 03:03 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Any way you look at it, it probably won't be easy.... making a mold and casting in clear resin isn't exactly the easiest thing to do.... and I'd be leery of heating up a piece of styrene to form the hood, because you can just as easily warp the original hood as shape the new one....
If the hood is relatively flat, just make a new hood out of clear styrene. It's available in sheets at your LHS (made by Evergreen plastics) in a number of sizes. I just bought a pack of 0.015" clear and 0.010" plain (this stuff rocks!!!!) last night. The 10 thou stuff is vital if you want to customize things (you can cut it with scissors, it's so thin...)
I work slowly!
Old 06-11-2003, 03:07 PM
Ya, I have used Styrene before, but never seen clear before. You probably have to special order it from the hobby store or something. So you think heating the styrene will warp the hood, probably so. What about the Clay idea, how do you think I could go about doing it with clay?
Old 06-11-2003, 03:15 PM
bah humbug's Avatar
Some of you guys are unlucky.
I just found clear styrene at an arts and crafts store, not even specifically for models. Sure they have models but very little and so ugly that I've never bought a model from them B4.
I've bought the clear styrene, it's thin.
The styrene was made by Plastistruct.
I think they're stryrene was meant for model trains.
A lot of they're sheats can be used as dioramas, because some of the sheets imitate roads, bricks ect.
I don't think that clear styrene will work though.
I think clear resin would be good but never heard of it or seen it nor never used it.
But I don't think it would be easy or cheap.
Old 06-11-2003, 03:27 PM
Thanks for the info everyone, keep it coming. I think I will try and find some of the clear styrene and mess around with it and see if I cant come up with anything. I myself have never heard of the clear resin either, and have no idea where to buy it. I dont even know were to start looking for clear styrene either, hahahhhaha
Old 06-11-2003, 03:57 PM
Come on guys, there has to be some more ideas or info...lets hear them. Thanks for your imput
Old 06-11-2003, 04:25 PM
ZoomZoomMX-5's Avatar
There's no cheap and easy method, nor any simple method. Good quality clear casting resin costs a small fortune. The best stuff comes from the Netherlands. You'd have to order a lot, and then you'd have to make a good, clean mold of the original hood. You're talking in the hundreds of dollars when it's all said and done.
You could make a mold of the hood in such a way that you cast a solid resin hood with the same basic "topside" detail as the kit hood. This resin would hold up better under heat than the kit hood. They you'd want to cut some clear butyrate material, probably .040" thick, and vacuum form it over the solid hood. It would take on the shape of the hood, and be clear. Not the easiest method, but the only one that will truly look good w/o getting a kit that already has a clear hood. You might be able to get away w/using the kit hood as the mold base, but you'll have to set it up in such a way that it does not flex when the vacuum is pulled.
You can look for the sheets of clear canopy film in hobby shops, made for heating over a candle and then pulling over a small part to take on that shape. However, a hood will be nearly impossible to do that way, too much surface area.
My Fotki Album
any one got ideas tacmeter Rodeo | Passport | MU 6 05-13-2008 09:17 PM
SELLING 91 Z34 RED unless somebodys got idea to turn motor MJB3 Lumina 4 03-30-2004 09:14 PM
GOT IDEAs ..??..on interior mods super_tuner403 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 12-29-2003 07:48 PM
I got an idea how fast my car is now.. Hybrid Boy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 16 01-01-2002 12:30 AM
I've got an idea, igor Chris New Categories and Forums Requests 10 05-23-2001 05:34 PM
