Old 06-11-2003, 12:40 AM
erbinone's Avatar
erbinone erbinone is offline
Need A New Clutch!!!
I got a 91 Hatch w/ a GSR in it and need a new clutch. I want some performance, but I don't want a hardcore race clutch. What is the diff. between sprung and unsprung and 4-6 puck??? Need to be a good daily driven clutch. Thanks in advance.
Old 06-11-2003, 01:49 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
You should try lookin into action clutch. I hear nothing but good shit about them. They are kinda pricey but well worth it.
Old 06-11-2003, 02:29 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Never heard of Action, so I can't say anything about them...
I would have to recommend ACT. They don't have "stages", but they mix and match pressure plates and clutch discs for your specific needs. Most likely, for your setup it would be a Heavy Pressure Plate, with a Street disc.
I have a Clutch Masters Stage 2 and I love it. From what I understand, They have come along way in the last 2 years. Back then, they were having a lot of quality control issues, with warped discs and shotty materials, but I have nothing bad to say about mine. I beat the snot out of it everyday, and it is strong
I would have ordered an ACT, but when I needed a clutch, they were on backorder. So I went with the CM.
Just remember to "break-in" your clutch for 500-700 miles before you beat on it.....you'll be glad you did later.
There's nary an animal alive that can outrun a greased Scotsman!
Old 06-11-2003, 12:39 PM
erbinone's Avatar
Kool, I will do that... ACT sounds good. Break it in like drive it normal right???
Old 06-11-2003, 12:51 PM
yea, well not "normal"....
Be very gentle when engaging 1st gear and and on the transition between gears. I set my Trip meter, and then forgot. I went 923miles before I realized I could drive normal.
I would say at least 700miles. It sucks, but its the proper way to do it, and your clutch will have better clamping force and will last longer
Old 06-11-2003, 12:55 PM
erbinone's Avatar
Great.... thanks for the tip!
Old 06-11-2003, 04:41 PM
mellowboy's Avatar
Well i think both of should search a lil more
'88 CRX needs new clutch rbpafc '88 - '91 Civic | CRX | Wagon | Shuttlee 3 11-09-2004 09:42 AM
need new clutch hovz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-06-2004 07:37 AM
Need new clutch...any suggestions YellowITR479 N2O | Turbo | Superchargers 6 06-05-2004 01:08 AM
STD Need New Clutch blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-04-2004 03:40 AM
How to know if my Jetta needs new Clutch? Toots Jetta/Vento/Bora 5 10-01-2003 12:06 PM
