Old 06-10-2003, 03:06 PM
91civhatch 91civhatch is offline
easiest way to remove pins from ecu
Whats the easiest way to remove pins from the ecu harness????
Old 06-10-2003, 04:43 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Get a tiny screwdriver, then while looking at the female side of the plug, you will see a little tab holding the pin in. Lift the tab up, and pull the wire from the back, and it pops right out.
Old 06-10-2003, 08:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i had a really hard time getting hte pin out
Team Lonely Drivers
Easiest way to remove oil pump? CavRacer Cavalier 2 03-19-2006 12:12 AM
Easiest way of removing Tamiya Epoxy Putty? ImolaEK Car Modeling 11 07-08-2005 08:49 PM
Easiest Way To Remove Mitsubishi Sticker Emblem? toicy4ya Off-Topic 6 06-20-2005 07:35 AM
Easiest way to remove headgasket from block and head? 4G4D Store '88 - '91 Civic | CRX | Wagon | Shuttlee 4 05-06-2005 07:31 PM
Easiest way to remove console around shifter?? NiSmO_zt 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 08-30-2003 01:38 AM
