Old 03-18-2006, 11:31 PM
CavRacer CavRacer is offline
Send a message via MSN to CavRacer
Easiest way to remove oil pump?
2000 Z24
I have already removed the oil pan, oil pump chain cover and tensioner as well as all the bolts that should be holding the pump cover plate yet I can't seem to get it to seperate so I can remove the sprocket (all that's holding the pump from coming out.)
Any advice would be appreciated.
2000 Cavalier Z24 5 Speed
Performance Mods
AEM Short Ram Intake
Bosch Platinum Spark Plugs
Magnaflow Exhaust
Visual Mods
Blue Led Interior Glow Kit
APC pedals
Painted Interior (half done)
http://www.cardomain.com/ride/2306352/1
Old 03-18-2006, 11:54 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Easiest way to remove oil pump?
not sure if this will help you but it might help someone who searches for this topic in the future, the haynes manual for your car/engine gives only 4 steps for removing the oil pump and they are as follows:
1. remove oil pan (it says to see section 12, which lists a 14 step procedure for removing the oil pan) if you want that let me know
2. remove the balance shaft chain cover and tensioner (again, it says to see a different section, so if you want that typed out, let me know)
3. remove the oil pump mounting bolts and separate the oil pump from the balance shaft assembly
4. remove the oil pump cover and the gears from the oil pump housing
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-19-2006, 12:12 AM
Yeah I have the Chilton's Manual and am still stuck on #3 of your list. It doesn't give enough detail.
Maybe it's cause I spent 4 hours ripping everything else out of the way in 0 degree celsius temperatures with no heated workspace. I've never removed an oil pump before so I don't know what the balance shaft is.
Performance Mods
Magnaflow Exhaust
Visual Mods
APC pedals
