Old 06-09-2003, 05:08 PM
CRXtc CRXtc is offline
Banned
B16A tranny rebuild questions
who makes a rebuild kit for these? (CABLE B16A TRANSMISSION) i have been searching and the only thing i could come up with would be using 92-93 GSR gears OR getting another tranny.....anyone? anyone?
Old 06-09-2003, 05:46 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
I'm pretty sure you can use the LS rebuild Kit, the gears are the same as a Type-R if it's a S1 tranny, the others I'm Not sure.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 06-09-2003, 06:01 PM
Banned
the LS rebuild kit would lengthen the gears correcT? i dont want that
Old 06-09-2003, 06:27 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
no. cause normally a rebuild kit doesnt replace hard parts like gears, only synchros, seals, and bearings.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-10-2003, 12:15 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
I just went and bought a S1 tranny ($250) . A lot easer I think.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 06-10-2003, 12:51 AM
EF You's Avatar
EF Life Giver
i have an S1, but i cracked the case and it leaks. im getting a YS1 from a 92-93 GSR, putting 1st thru 4th from the S1 in it, leaving 5th from the YS1, and putting LSD int it.
why? might you ask. the USDM YS1 isnt the same as the JDM YS1, its kinda an inbetween from the S1 and the USDM LS trannys. not quite so short, but not long. and since the JDM S1 is basically a type R tranny (cept for 5th and no LSD) i figure ill build my own type R tranny for a lot less. im getting the YS1 for 75 bucks, and an LSD for 200
Old 06-10-2003, 12:54 AM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
where you getting your lsd from??? i im in dying needs of one.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 06-10-2003, 01:10 AM
I have been dying to get a LSD for my S1... where did you get yours at for that price?!?!?! As long as it is not Phantom Grip... they are garbage!
Old 06-10-2003, 08:00 AM
EF You's Avatar
EF Life Giver
i got the LSD from my friend who blew his tranny
Old 06-10-2003, 10:11 AM
Banned
ok, so then a rebuild wouldnt necessairly change the gears just the syncros and i could use the LS kit........would that cause any problems though? and what LSD could i put into it? i want to get a quaife LSD for it BUT the problem is they dont make one for a B16A cable tranny....should i just get one for a b18a1 tranny?
Old 06-10-2003, 01:05 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I'm pretty sure quife makes lsd for our b16 tranny? If not then go with Kaaz.
Old 06-10-2003, 01:16 PM
Banned
THE reason i want quaife is because it is the torsen type not a clutch type......
Old 06-10-2003, 05:35 PM
EF You's Avatar
EF Life Giver
yes use one for a b18. all the B series cable clutch trannys use a lot of the same parts, cept that bastard from the prelude. you may have to change the ring gear on the diff, im not certain, ill let you know when i change my diff to an LSD
Old 06-10-2003, 06:05 PM
Banned
ok so i can use the LS rebuild kit and an LSD made for an LS tranny and i will be good?
94 Ranger Tranny rebuild freakyfire05 Ranger | Courier 0 09-11-2010 03:11 PM
4R55E tranny rebuild problem mrstubb Explorer | Explorer Sport Trac 1 05-30-2010 10:27 PM
B16a Head Rebuild Ricebrnr55 JDM Motor & Parts info/chat 1 12-28-2005 03:01 PM
Dilemma b16a or rebuild on b18a... johnnym '88 - '91 Civic | CRX | Wagon | Shuttlee 8 02-22-2004 05:08 PM
B16A tranny options CRX586 '88 - '91 Civic | CRX | Wagon | Shuttlee 7 07-02-2002 10:35 AM
