Old 06-06-2003, 12:00 PM
lcasados lcasados is offline
any ideas?
I just bought a 1991 3000GT VR4 a couple of weeks ago, and I love it. I have been dreaming of getting one of these beautiful cars for about nine years. Finally, I got it. Now I seem to have some problems. I'm not sure why, but I don't have any power. I am in the process of replacing the spark plugs and spark plug wires; hoping that will give me more power. At least a little more anyway. I have a feeling that thats not the only thing wrong with it. The RPMs don't want to go past 4.5k in any gear, and I can't accelerate worth a crap. Also, if anyone knows of a way to get a hold of a 1991 3000gt service manual, would you kindly let me know. Thanks.
lee
lcasados
Old 06-24-2003, 02:41 PM
Wilson_Shaw Wilson_Shaw is offline
Sounds like at least one of your Catalytic Converters is bad.
Old 06-25-2003, 03:19 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I don't see how his cats would be doing this based on the fact it was the plugs that were changed.
It may be as simple as a bad plug. Or you replaced the plug wires in the wrong order.
Changing the plugs will have little bearing on the amount of HP you'll produce. Get an open air filter, boost controller (and a decent gauge for it) and an open exhaust. You'll be flying then.
Resistance Is Futile (If < 1ohm)
Old 06-26-2003, 11:23 PM
chris26969 chris26969 is offline
my friends GSX had one bad plug , he couldng get past 50mph , odd but hey he changed it and it workd. Try that .
Mods :
-3" Full Cat back exhaust
-K&N Filter
-MBC
-Upper Intercooler piping 1g Flange
-Turbo Intake
-BOV
-2 inch Drop
-Red/Orange paint job
-17" rims
-Indigo Gauges
Old 06-26-2003, 11:26 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Check the plug gaps also... always.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 06-30-2003, 12:14 AM
The reason that it might be the catalytic converter(s) is because he is not able to go beyond 4.5k rpm's. A bad catalytic converter would not allow as much exhaust to pass through as a good one. Since more exhaust is trying to get out at higher rpm's than at lower rpm's, the engine will have a tougher time making any power when its rotating that fast. Also, because it has no where to go, the exhaust gets backed up into the engine. This could cause some serious engine damage if left unattended to.
Checking the spark plugs and the spark plug wires is also a good idea, but that doesn't sound like the problem, or at least all of it. Even with a bad spark plug or two, you should be able reach redline in first gear. Where bad spark plugs really hurt is in low-end power.
Old 06-30-2003, 12:20 AM
i see you own a SC2 , i dont follows those too often , how much HP do they run? Fast?
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 06-30-2003, 12:20 PM
It has 124 h.p. at 4,800 r.p.m.s and 122 ft. lbs. of torque. I read in either Road & Track or Motor Trend that it is able to hit 60 mph from zero in 8.5 seconds at sea level, and has an electronically limited top speed of 124 mph. Although its not that fast, it is fun to drive and gets decent gas mileage (30 m.p.g.).
Old 06-30-2003, 12:47 PM
not bad.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-22-2003, 07:20 PM
ttamn92 ttamn92 is offline
Send a message via AIM to ttamn92
first check your cats
sec. check your boost controler make sure you are making at least 9 lbs of boost my 92 had no pwr i put a good boost guage on it and found i was only making 6lbs (wastgate press.) do not trust stock boost guage! good luck
Old 07-23-2003, 11:53 AM
Trogdor Trogdor is offline
Send a message via AIM to Trogdor
sc2 ?
do u know how that sc2 compares to a stock honda civic ??? also do u know if they are the same engine as like the 2000 ???
^ De monkey said so!
Old 07-23-2003, 03:09 PM
Prelewd's Avatar
theives!
How about you make a new thread for this in the saturn or civic forum instead of stealing this guys thread.
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 08-02-2003, 12:58 AM
FlamePaintn FlamePaintn is offline
Check timing and timing belt...if it jumped due to wear, intake valves and exhaust valves will not open and close at proper times, reducing power. Although not 100%, carbon on your plugs may indicate a timing issue. Just had similar problem with my celica 'vert...low power, revved only to 4000 (instead of 6000). Acted as though it was a fuel restriction or breaking down coil...but timing belt had jumped significantly. Good luck.
Old 08-04-2003, 12:19 AM
Im2Fast4U Im2Fast4U is offline
How many miles does it have? Has it had it's 60K service? If you aren't sure, just do it to be safe. Like FlamePaintn said, it could be the timing belt so 60K is a must. Like others said, it might be the plugs too.
I highly doubt it has anything to do with the pre-cats or cat. Your theory on them holding back exhaust gas is um........well I just don't get it. Are you suggesting they may be clogged with something? If there is anything jamming them that means it came from the engine and then he has bigger problems than his cats and normally the only thing that goes wrong with the cats is a bad O2 sensor which I guess could have an affect too, so you might want to check those out. Other than that, I really don't know man. Good luck fixing it and congrats on the buy (even if right now it isn't working out for you too well).
1993 Dodge Stealth
yes, it has mods....
R.I.P. DAD NOVEMBER 3, 1952-NOVEMBER 25, 2002
I LOVE YOU
Any idea if any other struts fit the 96 MX3 tookalook MX-3 0 07-12-2009 07:31 PM
Does any one have any ideas? kingweevle Pick-Up 7 11-11-2005 06:56 AM
Any Transmission experts? Shifting Problems, Any ideas? browserealty C/K 2 06-28-2005 11:36 PM
idea on how to save $ on gas.. any ideas on how to make it work??? dmorlow Aurora 15 06-20-2004 03:57 AM
