Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-10-2005, 01:08 PM
kingweevle kingweevle is offline
Send a message via Yahoo to kingweevle
Does any one have any ideas?
1993 toyota pick up 22re having really intermittent broblem in the ignition circuit.Somethimee i'd be cranking all day,and the darn thing dosent start.Then in the morning ,I'd start it with one touch.
I have changed the plug wires, the distributer cap, and the plugs are all firing.At first I thought my problem was the igniter pack but i'm still not sure.Please help
Old 10-10-2005, 11:08 PM
91tpickup 91tpickup is offline
How about looking at the starter igniter.Well maybe i dont know for sure.Not enough information.
Sorry if i am wrong.I know nothing about my truck.
But hey good luck to you !
Old 10-11-2005, 01:20 PM
bjd088 bjd088 is offline
Re: Does any one have any ideas?
Are you getting fuel to the engine?
Old 10-12-2005, 06:58 PM
LayneP LayneP is offline
You mentioned the plugs are all firing, if you are certain that you have good spark when cranking it, try hitting it with starting fluid next time it won't start. If it starts with the fluid, check to see if your fuel pressure is bleeding off after you turn the truck off. It may be a bad fuel pressure accumulator
Old 10-21-2005, 11:50 AM
GDBSKE GDBSKE is offline
is the outside temp the same when it starts and when it doesn't? Maybe the cold start injector or the temp sensor is inop?
Old 10-28-2005, 07:35 AM
It appears that the truck is no longer giving the problem. I just cant understand how because it was really a pain. it fixed on its own."beats Me"
Old 11-08-2005, 06:01 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
check and clean and grease all wiring plugs underhood and at fuel tank and on pass side in the cab along the rocker under the carpeting(the fuel pump wire is in this and the connector is a real corrosion issue, i snipped mine off and crimped all the wires back together on mine)
corrosion in wiring plugs is a real problem on these trucks
very common
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 11-11-2005, 06:56 AM
SidneyCanada SidneyCanada is offline
When the problem is present and you crank does the tachometer (RPM gauge) needle jump up and down? it's supposed to if not yu have a coil related problem, usually the coils fail when they are underload like climbing a steep hill or acceletating hard.
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota/
http://members.igateway.net/~pscott/enginecodes.html
http://www.autobook.co.kr/data_links...uble_codes.htm
http://www.autoshop101.com/forms/h27.pdf
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
1985 Toyota 4-Runner/pickup Factory Service manual:
http://www.jasuza.com/1985toyotatruckfsm.pdf
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm/
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts/
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans/
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mecha...rams/index.htm
http://perso.wanadoo.fr/adherence.4x...techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html/
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/a...oyota.manuals/
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://www.autoshop101.com/autoshop15.html
http://www.mtv411.com/sitemap.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
