Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-14-2012, 08:02 PM
maliath maliath is offline
r134a replacement low side valve
Hi,
I have a 1994 Mazda B4000. I just tried to charge the A/C system via the low side port. The coolant went in and the A/C got nice and cold. However when I removed the hose, I noticed that coolant was leaking from the low side service port valve.
After searching the internet I'm finding that most low side valves are Schrader type valves. However, this is definitely NOT a schrader; it appears to be some kind of black ball valve. Obviously, I need a new valve. I'm hoping to do one of two things:
1. Purchase an adaptor that simply screws on the top of the old valve, but has a schrader inside instead, OR
2. Purchase a replacement valve. In which case, I'll have to unscrew the old valve from the system.
Has anyone run into this issue? Does anyone know exactly which parts I need to buy?
THANKS
Old 07-14-2012, 10:38 PM
tempfixit tempfixit is offline
Re: r134a replacement low side valve
Originally Posted by maliath View Post
Hi,
THANKS
Take a look at this kit possibly it is what you are looking for.
http://www.napaonline.com/Catalog/Ca...803_0158871006
Hope this helps
96 Grand Am 2.4 Location Low Side AC Valve? cukachew Grand AM 1 08-11-2010 10:21 PM
98 Blazer AC low side service port shrader valve Allbert Blazer 5 08-24-2005 02:24 PM
Where is low side A/C valve? j_p_lockwood Camry/Camry Hybrid/Vista 4 09-01-2004 11:08 AM
Low compression = valve replacement '93 metro Death_Metro Metro 2 07-23-2004 12:40 AM
