Old 08-24-2005, 09:08 AM
Allbert Allbert is offline
98 Blazer AC low side service port shrader valve
I tried to top off the R134A charge in my 98 Blazer AC system the other day, and when I decoupled the hose from the low side service port, the shrader valve inside gave up altogether and started leaking. I tried to plunge it a few times to see if it might re-seat, but no luck. Soooo, I went down to AutoZone to get a new shrader valve, and they sold me the same parts you would put in your tire valve stems. My question is, are these acceptable for service in an AC system, or does anyone know maybe if the rubber used in these parts will not stand up to the refrigerant and oil in an AC system?
Old 08-24-2005, 09:30 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: 98 Blazer AC low side service port shrader valve
Well at first I would say they may have gave you wrong one. The correct does look the same but a little bigger than the ones use in R12 systems. The R12 valve is the same size as what is in your tires. R134 valves are a little bigger in size, other wise should work fine.
Old 08-24-2005, 10:05 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
They actually sold you tire valves or do they just look like it?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-24-2005, 12:39 PM
Re: Re: 98 Blazer AC low side service port shrader valve
They gave me a little kit with 4 tire valves plus valve stem caps and a little 4 way tool for installing the cores or cleaning up valve stem threads.
Old 08-24-2005, 01:27 PM
DINO55's Avatar
DINO55 DINO55 is offline
Did the package say on it for AC shrader valve's? If not, take them back. I remember seeing the correct one's marked in a package at Auto zone.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 08-24-2005, 02:24 PM
BlazerLT's Avatar
AF -Advisor
Autozone idiots strike again.
