Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-13-2012, 01:53 PM
badger6 badger6 is offline
98 3.2 Starting issue
98 3.2 with 150k. During the day in warmer weather the engine seems to start on first key turn in 1-3 seconds. If it sits over night, it won't crank on the first key turn. Have to turn to ACC and let the fuel pump do its thing for 4-5 seconds on the first and second try to get to start. Seems to run fine while driving and starts right back up. From reading here, and tell me if I'm wrong. It could be, MAF sensor, crankshaft position sensor, fuel pressure regulator ? What would you guys check first easiest to hardest ? I ain't too mechanical, ha ha.
Old 07-13-2012, 11:40 PM
Cat Fuzz Cat Fuzz is offline
Re: 98 3.2 Starting issue
There is a check valve in the fuel pump assembly that is known to fail from time to time. This check valve, when working properly, will hold the fuel pressure in the line. When it fails, fuel pressure slowly bleeds off over night. You can attach a simple fuel pressure gauge directly to the schrader valve on the fuel rail (looks like a tire valve) and observe the pressure. It should hold over night but it probably isn't.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 07-14-2012, 04:47 PM
Don't you have to drop the tank for that ?If so, I don't think that I'll be doing that job, ha ha. Besides wasting an extra 20 seconds a day, could that cause any other problems if not replaced ?
Help! '02 Ram 1500 starting/not starting issues wallace7304 Ram Pickup | Ram SRT10 2 06-14-2010 08:48 AM
1999 4.3 Cold Start Issues DanCovey Problem Diagnosis 3 04-26-2008 08:40 AM
Rodeo 2001 3.2 Starts rough when cold and ofter dies martin_ga Rodeo | Passport | MU 5 05-22-2006 04:13 PM
94 Supreme 3.1 starting issues danieljay Cutlass Series 2 11-07-2005 10:06 PM
1994 Taurus SHO 3.2 electrical issue/alternator boggs301012 Taurus | Taurus Wagon 1 10-31-2003 12:36 PM
