Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-14-2010, 06:52 AM
wallace7304 wallace7304 is offline
Help! '02 Ram 1500 starting/not starting issues
Truck was fine. Got in to go and wouldn't start. Checked fuses and relays. Still no start. Hooked it up to a code reader and no codes. Truck decides to start. Few hours later, it won't start again. After hooking back up to code reader, it started, still no codes present. Checked the coil and replaced the crankshaft position sensor, was running. Few hours later, won't start....please help. This is frustrating! Any ideas!?
Old 06-14-2010, 07:46 AM
radioconsult radioconsult is offline
Re: Help! '02 Ram 1500 starting/not starting issues
Check the starter itself, when a starter fails it usually occurs suddenly and usually when you are somewhere that really creates a problem. Sometimes you can take a hammer or wrench and tap on the starter while someone turns the key. My wife's car starter dield at the post office a couple of months ago and I had to call a wrecker to get it home.
Old 06-14-2010, 08:48 AM
I don't believe its the starter. It's cranking it just won't fire....I am not a mechanic by any means though....?
