Old 07-13-2012, 02:43 PM
frafreg frafreg is offline
A/C Low Pressure High and High Pressure Low
Long story short, my original compressor seized. I replaced the compressor with an exact replacement from the junk yard and installed a new clutch. I added 6 ounces of oil to the compressor and 2 ounces to the accumulator as per the manual. I replaced the low pressure switch, the accumulator, the orifice, all the seals, flushed the condenser and evaporator, evacuated and charged with 36 ounces of 134A. I had almost the same results with 24 ounces of R134A as I do with 36 ounces of R134A. I think I have a bad compressor but I don't want to waste any more money if I'm wrong. Also, if I replace the compressor, I'll be forced to replace the accumulator and probably the orifice again, not to mention the cost of more R134A. The condensor fan is operating properly and the compressor is not slipping or shutting off. There is no blockage in front of the condensor or radiator. There is plenty f aire flow through the condenser. There is no overheating condition of the engine. I'm stumped! Thank you in advance for any help. I appreciate it.
Here are my readings @ 95 degrees ambient temperature
System Off - Static Readings
Low= 115 High=115
System a @ Idle
Low=75 High=155
System @ 1500 RPMs
Low= 50 High= 180
System @ 3000 RPMs
Low=35 High= 230
1990 Jetta Carat engine's rpms fluctuate between low and high rpms adammarker '83 - '90 1 02-05-2013 03:41 PM
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 12:46 PM
Oil pressure light and overheating danz409 Cavalier Problem Diagnosis 3 11-20-2011 05:41 PM
No fan speed on low and low/medium but fan works on med/high and high treavie Cavalier 1 05-16-2007 01:30 AM
My truck idles high and low, high and low... PRF Pick-Up 3 01-13-2005 10:53 PM
