Old 07-12-2012, 11:16 AM
crys82 crys82 is offline
2002 Buick won't stay running
My car will not stay running unless you press on the gas and then wants to stall at every stop or sometimes when I have to brake. It has been doing this on and off for a couple of days and seems fine once you are running at higher speeds and seems to mostly stop acting up after the cars is ran for 5-10 miles.
Old 07-12-2012, 02:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2002 Buick won't stay running
Remove the Idle Air Control (IAC) and clean/inspect. Also check for vacuum leaks on all hose & fittings.
Help Needed 2002 Denali Wont Stay Running Eviltwincustoms Yukon 3 06-28-2008 03:25 PM
88 Buick Regal won't stay running doowah Regal 12 01-21-2008 07:55 PM
2002 SL1 won't stay running computer problems yue_mike SC/SL/SW 1 08-24-2006 11:29 PM
Won't stay running Deanna Bonneville 8 01-13-2004 06:51 PM
Ford Tempo won't stay running rdsaylr Engineering/ Technical 3 08-04-2002 04:50 PM
