Old 07-10-2012, 10:57 PM
enslow enslow is offline
Engine noise during warmup
For the last few years I noticed my wife's 97 Lesabre was rather noisy while warming up. It was mainly engine noise, not knocking. I cannot rule out all vacuum leaks, although I have already replaced a number of the hoses. I remember reading either here or on another forum that some have complained about engine noise during the warm up as well. Some have it, some don't.
I recently discovered that I had some very slight exhaust manifold leaks. Not enough to smell exhaust, but enough I could feel a slight breeze on my hand when I held it in certain areas by the manifold. (And, no, it wasn't the fan). I tightened the exhaust manifold bolts and the engine is quieter now. All I have to do is get rid of the power steering whine and an alternator chatter.
Some have blamed the IAC, vacuum leaks, etc. Those are possible sources of noise. I'm posting this because if you have engine noise during warmup, you may wish to try tightening your manifold bolts about 1/16 of a turn. Also make sure the donut gaskets at the crossover are sealing too.
The Following User Says Thank You to enslow For This Useful Post:
HotZ28 (07-10-2012)
Old 07-11-2012, 06:35 PM
Tech II Tech II is offline
Re: Engine noise during warmup
They are known for the exhaust "doughnut" between the manifold and the exhaust pipe coming apart, and creating a noise......
Old 08-06-2012, 08:59 AM
edwinn's Avatar
edwinn edwinn is offline
Buick Enthusiast
I've had a grinding-sucking noise in my Riviera 3800 engine during warm-up in COLD weather ever since purchasing it in 1998. It's understood to be a passage in the intake/throttle body that functions as a choke or fuel enrichment circuit? {cannot remember the correct terms} and was told that it's normal. It sounds like running a knife around inside an empty glass mayo jar of slightly more noisy!
-Ed
Old 08-10-2012, 12:56 AM
I've done some further looking into the issue. The problem is definitly with the exhaust manifold. I stuck a vacuum on the blower mode through the exhaust pipe and felt around the exhaust manifolds as best I could. I still felt air coming out from the manifold right near the #5 cylinder. I tightened the manifold bolt a little more and I think I stopped the leak, and the engine is a fair bit quieter.
I had trouble with the donut gasket before, but this is definitly the exhaust manifold. I can't fit my hand in around the rear manifold from above, but I wouldn't be suprised if the rear had a leak too. I suppose both manifolds should be changed soon.
Ed, you may wish to look at your exhaust manifolds too. I thought it was a vacuum leak at the intake for over a year, because that's exactly what it sounded like. Turns out I was wrong.
Old 08-10-2012, 08:05 AM
edwinn's Avatar
Buick Enthusiast
I've done some further looking into the issue. The problem is definitely with the exhaust manifold. I stuck a vacuum on the blower mode through the exhaust pipe and felt around the exhaust manifolds as best I could. I still felt air coming out from the manifold right near the #5 cylinder. I tightened the manifold bolt a little more and I think I stopped the leak, and the engine is a fair bit quieter.
I had trouble with the donut gasket before, but this is definitely the exhaust manifold. I can't fit my hand in around the rear manifold from above, but I wouldn't be surprised if the rear had a leak too. I suppose both manifolds should be changed soon.
This is a revelation, because the Buick dealer who "found" the lo-miles Riv for me said the noise, which was VERY prominent in winter weather, was the intake system. Not easy to diagnose because you only have a few mins in COLD weather to find the problem.
I'll state it again.. the noise is described as "running a table knife around inside an empty glass mayo jar" and there's a "clanking" or grinding component to the sound as well, almost like very rapid drumstick tips. It goes away in a few minutes. I've lived with this for 15 years and have normalized it.
Concerning the manifolds.. are you talking about where they bolt to the heads? Wouldn't there be evidence of a leak with black soot or carbon deposits nearby?
-Ed
Old 08-10-2012, 10:37 AM
Sure you are not confusing the noise with the air pump?
The air pump comes on, on a cold engine....the length of time is determined by the startup temp of the coolant.....
Old 08-10-2012, 10:40 AM
Ed,
I suppose there would be a black spot, although the newer cars burn far more completely than the cars of 25 years ago. Keep in mind I'm looking from above so I cannot actually see the spot, just feel it when I reach in there.
Your noise could be intake, but it could be worth checking the exhaust manifolds. They head up within a minute. I know that sometimes when the dealership doesn't know, they will feed you a line to answer your question. These lines usually come from the "service advisor", not the actual mechanic that works on your car because the mechanic is often conveniently hidden behind the service techs. (Nothing bad against the mechanics, more a comment about the dealership structure.
Old 08-18-2012, 10:42 PM
Could be on Ed, but not mine. I have no air suspension, and I have confirmed it is leaking at the exhaust manifold.
I am considering changing the front exhaust manifold. Is it worth considering the Dorman? Should I get GM? If I get Dorman, they come with manifold gaskets. GM didn't use gaskets at the factory, and doesn't supply gaskets with their manifolds.
Old 08-19-2012, 12:16 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
I think what TechII was referring to was an air pump on the engine, which neither of these have. Obviously, the rear air ride compressor has nothing to do with engine start up temp.
Gaskets make imperfections such as warping and uneven surfaces more forgiving, hence the use of header gaskets when used in conjunction with tube headers. I would not hesitate to try Dorman for this purpose, especially if cost is a factor.
Old 08-19-2012, 07:23 AM
edwinn's Avatar
Buick Enthusiast
Had normalized the issue and dismissed it, but now since the topic came up.. am hearing the grinding clatter sound on start-up, in the garage in August. Not a cold weather issue (although it's worse in cold weather) but a cold engine issue. It's more prominent with the hood open, and definitely not the air suspension pump. Haven't seen a manifold air injection pump since the 350 CI V8 engines.
The sound (once more) is described as "a blunt dinner knife running around inside an glass mayo jar" together with "screws clattering in a coffee can" and a "drumstick 'tipity-tipity' component." So there's a grinding, clatter and rapping component all combined. It's rather loud, yes!!
I still think if there was exhaust leaking then you'd have a soot residue. Have we dismissed the air induction/cold engine/choke explanation? That's what the dealer told me who diagnosed it. Let's get this one figure it out.
-Ed
Edit: tell you what... I'll endeavor to make a hi-def video of this in stereo, mounting the PowerShot camera on a tripod aimed at the engine compartment and start 'er up.
Old 08-19-2012, 10:49 AM
You may not be able to see the soot. I certainly didn't notice any. If the exhaust leak is on the underside (like mine), you'll be hard pressed to see the soot. The easiest way to find it is to use a smoke machine (which I don't have) or try a shop vac on blower mode through the exhaust tail pipe, then feel around. Mine was quite hard to find. I didn't feel any air rushing for a minute using the shop vac trick. It could only be felt from one angle. A smoke machine would definitely be better.
Old 08-24-2012, 08:17 AM
edwinn's Avatar
Buick Enthusiast
Anything new on this topic? Would like to get more feedback / input from GM guys or dealer Techs that it's a known issue. I'm more sensitive to the nosie now and noticing the "clatter" at each start-up, even in summer weather. It will be WORSE in cold weather.
-Ed
Old 08-24-2012, 11:34 AM
An old trick to find ex manifold leaks, was to remove a couple plugs(one on each bank) and add a few drops of oil in the cylinders...replace plugs and start the car.....smoke would come out where the leak was....
Old 08-26-2012, 12:15 AM
HotZ28's Avatar
AF Moderator Elite
The sound (once more) is described as "a blunt dinner knife running around inside an empty glass mayo jar with" together with "screws clattering inside a coffee can," and a "drumstick tip 'rapity-rapity' component." So there's a grinding, clatter and rapping component all combined. It's rather loud, yes!!
-Ed
Ed, do you have a supercharger coupling clatter? Take the S/C belt off and check for back/forth play in the snout coupling.
Old 08-26-2012, 07:35 AM
edwinn's Avatar
Buick Enthusiast
Originally Posted by Edwinn
Tell you what... I'll endeavor to make a hi-def video of this in stereo, mounting the PowerShot camera on a tripod aimed at the engine compartment and start 'er up.
No sir, it's a L36 engine with a single accessory belt. The two explanations I have are:
1) Induction/intake noise with cold engine - worse in winter,
2) Exhaust leak with cold engine.
It's a clatter all right.
See post above where I've clarified the description of the sound (with underlines.)
-Ed
Quieting engine noise Allroader04 Cars in General 1 08-01-2011 04:50 PM
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
