Go Back   Automotive Forums Car Chat > Cars in General
Old 07-31-2011, 06:55 PM
Allroader04 Allroader04 is offline
Quieting engine noise
Just wondering what everyone thinks about the advice in this article on stopping engine noise. Is this good stuff to do? Are Lucas Oil products worthwhile?
http://www.ehow.com/how_10003617_stop-engine-noise.html
Thanks!
Old 08-01-2011, 04:50 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Quieting engine noise
Thanks!
G'day, welcome to AF
It's a pretty good basic article, but, it's pretty clear that it aims to push the use of additives, and this should always raise alarm bells, as anyone wanting to sell something is always going to recommend it use, whether you actually need it or not.
The only time I've seen oil additives have any positive effect on a car, has been on older engines, with lots of wear that were originally built with bigger tolerances.
Think anything English or American from the 60s and 70s.
On more modern cars I have seen additives cause problems.
Anything made in the last 10 years will be made to much smaller tolerances. As a general rule, this means they need to run thinner oil. If there is no significant wear, then adding a stabilizer, or additive can thicken the oil and cause problems with pressure and flow to critical areas in the engine, which will cause premature wear.
In some cases I have even seen it stop oil pressure dependent functions like VTEC on a Honda from working.
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
Tags
engine , noise , quiet , squeal , whine
