Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-16-2010, 12:16 PM
83mb380sl 83mb380sl is offline
'81 Deville 368 engine noise
I have a noise in front of the engine that kind of sounds like a bad bearing. It's not any of the accessories. I can remove all of the belts and it still makes the same noise. I put a new distributor in it recently. It quiets down some when I put it in gear. Is there anything it could be besides the front main bearing? The engine is the 368 V8, engine code 9.
Old 10-16-2010, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: '81 Deville 368 engine noise
From here a noise is tough to give advice on, I was a Cadillac field troubleshooter when those cars were new, lots of issues but not with the engine itself. Sounds like a bad bearing knocking or a rotating bearing grinding? Are you sure it is not from the torque convertor area?
Old 10-17-2010, 06:09 PM
I won't get to looking at it for a couple of weeks. The car is located about an hour from where I live. I thought the noise was at the front of the engine. But, I did have a little transmission fluid under the car, which I thought was dripping from the transmission pan. It wasn't much, the fluid level is ok. I'll do some checking in a couple of weeks. Thanks for your reply maxwedge!
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 09:04 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
Tags
engine , noise
