Go Back   Automotive Forums Car Chat > Hyundai > General Discussion
Old 07-10-2012, 07:11 PM
dmgolub dmgolub is offline
Question Fueling issue....
OK, Hyundai Accent 2004. Every time I go to ANY gas station to gas this vehicle, the gas pump shuts off every 2 seconds. It didn't used to do that. What happened? The car runs good, just filling it with gas at the station has become a problem. Think something wrong with the fuel tank?
Old 09-20-2012, 09:30 AM
smwhis smwhis is offline
Re: Fueling issue....
I have the same problem with a 2003 Tiburon
Old 09-20-2012, 05:21 PM
My mechanic wants $200 to drop the gas tank, and replace the sensor that's causing the problem. I'm just going to keep this lousy Hyundai through the end of this year. Then, NO MORE HYUNDAI'S. Cheap, crappy vehicles.
Old 09-24-2012, 07:54 AM
I repaired the 2003 Tiburon this weekend, it took about an hour. I did not have to drop the tank, I just removed the two bolts and two nuts holding the charcoal canister, removed the two fuel vapor connecting lines, the electrical connection to the sensor. Once removed cleaned out the charcoal that clogged the vapor lines. I installed a small screen (from a water faucet), reinstalled in reverse order: Problem solved, I can now fuel car with no issues. Cost & 0.00. Hope this helps.
Old 08-01-2014, 12:36 AM
ritu sen ritu sen is offline
The best solution of this problem, Change your car gas tank.
01 2500 8.1 Suburban Fuel Gauge Issue aptivaa12 Suburban 2 08-25-2010 08:47 AM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
2000 Metro Fuel Tank Issue. Unbelievable!! dkvarda Metro 1 07-30-2009 05:34 PM
Fuel Issues?????? finigini Grand Marquis 5 02-04-2005 10:15 PM
one more quick fuel issue... maxspeedhonda Forced Induction 0 06-11-2003 08:41 PM
