Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-10-2003, 11:22 AM
finigini finigini is offline
Unhappy Fuel Issues??????
I have a 94 Marquis - great shape, all regular maintenance. Had a thorough tune up last year. Yesterday I pulled out of my driveway and the car starts bucking. I park the car in the driveway and borrow a friends. This morning, I start my car, and it seems like there is a problem with the gas flow??? The car starts, then dies out, sputtering. Occasionaly it may make a backfire sound. All parts that I can think of, fuel pump assembly, filter, sensors, etc. were replaced last year. Any suggestions on what I can try?
Old 10-14-2003, 06:30 PM
MarquisGT MarquisGT is offline
That sounds exactly like what my car was doing (except for the backfireing noises). It was the EGR valve and ports, which were all clogged up from years of the engine burning oil. It was caught by a computer diagnosis, so you might want to start there to make sure that is definately the problem, but like I said... almost exactly what mine was doing. You can see here: http://www.automotiveforums.com/vbul...d.php?t=140692
To effectively clean the ports on that engine, thoguh, you have to take off the air intake, throttle body, and plenum assembly. Then you are basically looking right into the EGR.
Old 11-04-2003, 02:59 PM
That was the exact problem. Of course, there were a couple of other valves that they said needing replacement, but now she rides like a dream. Thanks.
Old 12-20-2003, 10:22 PM
samlar samlar is offline
Re: Fuel Issues??????
Fords have a bad problem with the throttle valve body causing this problem. You can buy stp throttle valve body cleaner and remove the air instake hose from the throttle body and clean it. If you take it to ford they will replace it or charge you a arm and leg to clean it.
Old 02-04-2005, 09:53 AM
namvet9th namvet9th is offline
i have a 93 mercury grand marquis and i parked it one night and it has'nt started yet.i think ity may be the fuel pump but would like to know how to replace it.
Thank,
Paul(namvet9th@ aol.com
Old 02-04-2005, 10:15 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
about the 93 when u turn the key to the run position do u heear the fuel pump "prime" or turn on
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
