Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-10-2012, 11:48 AM
9dreizig 9dreizig is offline
Tahoe A/C compressor question
I purchased a new aftermarket A/C compressor for my 98 Tahoe.. It looks drop in with the exception of the OEM version had an extra 2 pin connector on the back of the compressor.. This looks to be built into the unit ..
My question is can I run the new one without this ?? I called the supplier and he said he sells 200 a month of that unit with no problems. Suggestions ?
Old 07-10-2012, 12:20 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Tahoe A/C compressor question
That extra plug is a pressure switch, it needs to be swapped over. It's held in place with a spring retainer.
Old 07-10-2012, 12:27 PM
That's what I figured.. The problem is it's not compatible with what I have with the new compressor.. The new one has a screw in type fitting .. I just pulled the old one and it's press in with the spring clip retainer..
Any suggestions where to get a different pressure switch ?
Old 07-10-2012, 03:00 PM
brcidd's Avatar
brcidd brcidd is offline
That plug fits into the HPCO high pressure cut-out switch- which is normally closed and opens at 425 psi- so it must be jumpered or mounted to run the compressor.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-10-2012, 08:40 PM
j cAT j cAT is offline
what you must get is the same compressor type so that the high pressure cutout switch can be mounted.
on my 2000 silverado this is not on the compressor but at the condensor near the orifice tube. you must have the wrong compressor. as mentioned it should be installed on the back of your new compressor with the C clip lock .
I would not use that new compressor.
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 04:45 PM
AC compressor question, need answer ASAP CRXtc '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-31-2003 07:51 PM
affordable compressor questions UncleMeat777 Car Modeling 21 05-20-2003 01:53 AM
Compressor Question...... rcmaxx Car Modeling 1 06-18-2002 08:49 AM
Compressor Question JE123 Car Modeling 4 03-26-2002 09:25 AM
