Old 07-08-2012, 11:29 AM
shelbberz shelbberz is offline
my camaro 89 rs
i have 2 issues with my 89 camero the first one is
some times if im seating at a stop light it will just die out but it will restatrt right away
the second is if i have been driving it for a while and and i turn the car off and its been setting for a few minits say like 30 i got out to start it and i turn the key nothing happens no sound no clicking the lights and all the gauges and the radio works but nothing happens unless i let it set longer then it will start right up and run perfect except for the stalling out some times at stop light can any one help me out here any suggestons thanks
Old 07-10-2012, 05:10 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: my camaro 89 rs
Start simple, I would change your fuel filter to start. If it keeps happening check the fuel pressure at the rails.
The second part is probably your vats (vehicle anti theft system), the chip in the key.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 07-10-2012, 10:40 AM
Tech II Tech II is offline
Re: my camaro 89 rs
Which engine is this?
Old 07-12-2012, 05:09 PM
Re: my camaro 89 rs
305tpi
Old 07-12-2012, 05:10 PM
Re: my camaro 89 rs
how do i check my vats on my key ?
Old 07-13-2012, 06:28 PM
goldz28's Avatar
Re: my camaro 89 rs
You should be able to take an ohm meter and check the resistance of the chip.
Old 07-13-2012, 10:06 PM
Re: my camaro 89 rs
Sounds like two seperate problems.....VATS will NOT cause a stall at a redlight.......possibly an IAC problem.....
No start could be a Vats problem.....one thing to do, when it won't crank, release the key to the "on" position, and look at the SECURITY light.....if it stays on, then you definitely have a VATS problem.....if it isn't on, it could be the starter enable relay circuit, or a bad starter.....
If the SECURITY light is on(should go out after 5 seconds with the key on), the usual culprit is the wire(s) to the lock cylinder......remove the driver's side hush panel......look at the steering column......coming down the column you will see an orange sheathed harness with two white wires, going to a black connector.....take an ohm reading of the key(two contacts on each side)......disconnect the black connnector and attach the ohm meter to the harness going up the column.....insert the key.....should get the same reading.......now rotate the key to the crank position and back to off several times..........the reading should be constant.....if it goes "OL" while rotating the key, you have a lock cylinder problem with one or both of the wires.....lock cylinder has to be replaced or you attach a resistor with the same resistance of the key to the opposite side of the black connector(not the side going up the column)..........
Lingenfelter 750 hp 2010 Camaro SS L28 Featured on Powerblock TV Tim@Lingenfelter Camaro Discussions 0 01-13-2010 11:57 AM
2010 Camaro SS vs 1968 Camaro SS trev0006 Car Videos 0 06-03-2009 10:09 PM
Camaro VS Camaro VS slowstang SMOKEY818 Camaro Discussions 3 08-16-2004 01:59 AM
1996/1997 Camaro SS or 1998-2002 camaro SS????? chevynutss Camaro Discussions 39 07-18-2004 12:38 PM
1967 camaro 427 SS or a 2002 camaro SS dapriceiswrongb Car Comparisons 4 06-27-2003 12:40 AM
