Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-05-2012, 07:28 PM
snappy|nuts snappy|nuts is offline
Send a message via ICQ to snappy|nuts Send a message via MSN to snappy|nuts
Unhappy 2003 Malibu Electrical problems :(
I have replaced the ignition switch and lock cylinder as suggested by someone. This made absolutely no difference with my issues. The key stays in the ignition now, that is about the only plus....
Here are my symptoms:
  • radio works sometimes
  • "THEFT SYSTEM" light flashes as soon as I turn the key on to "ACC"
  • car starts, then shuts off immediately
  • key-less entry/lock doesn't work at all
  • panic button and trunk pop buttons on keychain do nothing
  • trunk sometimes pops open on its own when I turn the key
  • door chime rarely works
  • fuel gauge rarely works
  • temp gauge rarely works
  • A/C compressor will not kick on when the button is pressed
could this be the computer? I'm at a loss here and I really need this car working.... please help. I can't afford to take it to the dealer and I can't even sell it like this.
any help would be much appreciated
tks,
-ry
Old 07-09-2012, 04:44 PM
Re: 2003 Malibu Electrical problems :(
update:
got the car to start after I ran the "relearn" procedure for my new ignition.
The A/C works if I remove the relay and jumps pins 30 to 87.
I'm being told this could be a BCE issue.
Old 07-09-2012, 05:47 PM
Tech II Tech II is offline
You have a list of problems, that could be individual problems in themselves.....
What do you mean? Does the faceplate light up? Or is it just a sound problem or reception problem?
You oviously had a Security system problem.....the relearn may only be a temporary fix....Was this PassKey or PassLock? If PassLock, was the PassLock module replaced?
Possible bad key fob or battery.....
Disconnect the actuator in the trunk.
Are you talking about opening the door with the key still in the ignition?
Usual problem is a sending unit in the tank.
Need to hook up a scan tool to see if it's a sensor or cluster problem.
You have bypassed the whole system by removing the relay and jumpering the feed to the A/C clutch with power.....possibilities are bad relay, a code is set, low freon, bad pressure sensor, etc.
Sounds like you've had a list of problems that you let accumulate......
Old 07-11-2012, 12:38 PM
- sometimes when I press the display button on the radio I will get the clock, but I can't turn the radio on. Its almost like its doesn't know the ignition key has been turned on. Other times it works perfectly, but very rare!
- I'm not sure about PassLock or PassKey.... I did change the lock cylnider with the ignition
- tested with two FOBs and new batteries. Even tried a "re-sync" by holding down the UNLOCK and LOCK buttons simultaniously... still no go.
- I think this is a symptom of the larger electrical problem I'm having.
- yeah exactly or opening the door with the head light switch still on with the engine off
- yeah I'm being told that this is needed.... I'm trying to spend as little money possible but it seems this is unavoidable
- I did this just to make sure the problem wasn't the compressor or the hydrostatic clutch. I'm going to start with a new control head unit for this as the heat/cold door actuator isn't working either
This all started after I left the car for 7 weeks parked in a friends driveway. He had to boost it a few times using a battery charger with a "boost" option on it. Personally I think he fried something as everything worked perfectly fine prior to me leaving the car there. Now I have to fix all of this so I can at least sell the car. No one wants to buy it with nothing working. I appreciate your help!! I will provide updates as I get systems working again. As mentioned, I'm trying the control heads next..... I'm being told by others that this is a BCM problem though.....
Old 07-11-2012, 07:33 PM
Sounds like your electrical system was "spiked", especially if he did this while the key was "on"......
Old 07-12-2012, 12:59 PM
I also checkde all fuses in both internal blocks and the under hood block and none are blown.
Any relays related to systems that aren't working seem fine too.... definitely computer/BCE related issue I'm thinking.
Old 07-16-2012, 06:24 PM
when I remove the truck release fuse everything miraculously starts working again.
With the fuse back in, I lose the fuel gauge, temp gauge, A/C and stereo
This makes no sense.
With the fuse in the trunk release works fine... but the keyless entry with the fobs doesn't work in either scenario.
99 Malibu electrical problems - update kbridges56 Malibu 2 03-12-2009 03:34 PM
2003 Malibu having problems starting MsHershey Malibu 3 05-21-2007 02:37 PM
1998 Chevy Malibu Electrical problem Musicaspiration Malibu 0 08-09-2006 01:25 PM
99 malibu electrical problem? bigtom7 Malibu 5 06-26-2005 08:27 PM
2003 1500hd electrical problems thesaint C/K 4 08-10-2003 01:33 PM
