Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-20-2007, 09:18 PM
MsHershey MsHershey is offline
2003 Malibu having problems starting
We are having problems with the car starting. It doesn't happen all the time just occasionally.
My husband is a backyard mechanic and has replaced the following items:
Spark plugs
Fuel Filter
Last year the fuel pump went out and we had that replaced by the Chevy dealer.
For example, today I left to go to church, the car started fine. I stopped at a convenience store, the car started fine. Went to church. After church came out to crank it. It goes vrr,vrr and stopped. I tried again, goes vrr, vrr and stopped. I turned the key completely off. Turned it back on, waited for the fuel injector thing to complete and vrr, vrr it cranked. This is how it has been acting lately. Does anyone have any ideas?
Old 05-21-2007, 09:54 AM
NocturnalCreations's Avatar
NocturnalCreations NocturnalCreations is offline
Re: 2003 Malibu having problems starting
I had the same problem. The first thing I did was check the fuel pressure. My fuel pressure was good and it turned out to be a passlock issue. We have a bunch of threads on paslock problems and how to bypass them. Check them out and see if it sounds like your problem.
Good luck
97 Seville STS
95 Lumina about to get a 3.8 supercharged
97 Mustang 3.8
06 Charger RT 5.7
Check out the 1 of a kind whips
http://www.cardomain.com/id/NoctrnlCreations
Old 05-21-2007, 10:39 AM
Thanks for the response. I will check out those threads. But in the meantime could you give a brief description in regards to pass locks?
Old 05-21-2007, 02:37 PM
Read this http://www.automotiveforums.com/vbul...d.php?t=454520
You can also search this forum for any info you need. There is a ton of info on passlocks here.
97 Seville STS
97 Mustang 3.8
06 Charger RT 5.7
