Go Back   Automotive Forums Car Chat > Toyota > ECHO/Vitz/Yaris
Old 07-04-2012, 08:59 AM
neeleshgupta8480 neeleshgupta8480 is offline
Post Changing Engine Oil (Mobil)
Hi Friends ,
Greetings for the day,
I Have purchased Yaris Sedan 2008 (at 65k Kms) as my first car before 6 months back,
At 70k kms I have got it serviced as followed :-
* Engine Oil Brand name was = CALTEX 1 lts (Texamatic 1888 (automatic transmission fluid) attached is the image as well,
* Oil Filter Changing
* Air Filter
* Gear Oil Manual
* Radiator Water
Kindly advice now at 75k kms I have to replace engine oil, some one advice me to use mobil 5W-30 synthetic oil but here in UAE this brand is not available, pls suggest :-
* Can I use Mobil 10W 40 (for 10k kms, which is semi-synthetic)
* New Oil Filer + Air Filters are required
* Gear Oil required as well,
Also advice what all i need to replace/fill at each 5000 kms service..
i am sorry for the long story....
Many thanks for kind advice/help to all you in advance
Jet .
Old 07-07-2012, 08:14 PM
Willyum Willyum is offline
Re: Changing Engine Oil (Mobil)
The technical differences in the oil weights you describe are minimal.
I can't tell you what you can and can't do but I'm assuming that temperatures where you live range into the 90o plus range often. I live in southern Nevada and have used 20-40, 10-40, and 10-30 in my Ford Taurus without any noticeable difference. I put the heavier grades in for spring and summer, then by fall use the thinner. I garage my car so it never gets started in very cold temp's but I have 115,000 miles on it and I've not done any damage to the engine.
Old 08-02-2012, 10:49 PM
Joe W Joe W is offline
I must question the oil you replaved in the engine as you indicate it as * Engine Oil Brand name was = CALTEX 1 lts (Texamatic 1888 (automatic transmission fluid). This is automatic transmission fluid and is unacceptable for the engine. The engine should use 5W/30 motor oil for the best performance. You also indicate the Yaris has a manual transmission so no automatic transmission fluid is required. If 5W/30 is unavailable then 10W/40 would work... but try harder to find the 5W/30. If you want to change the engine oil every 5K, I would recommend using synthetic oil as it is much more expensive, but does have a longer change schedule.
change engine oil light emmitt69 Silverado 3 01-12-2005 04:35 PM
Change Engine Oil Light PROV1 Montana/Montana SV6 12 01-08-2005 02:02 PM
Anyone know how to reset the change engine oil light to turn off shroom242 Impala | Impala SS 7 09-22-2004 11:34 PM
Change engine oil display ihunt49 Sierra 5 12-19-2003 06:34 PM
Tags
change , engine , filter , gear , oil
