Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-30-2003, 12:08 PM
shroom242 shroom242 is offline
Anyone know how to reset the change engine oil light to turn off
I have a 2003 Impala and I changed the oil myself and dont know how to reset the change engine oil light on the dash so that it does not come on anymore. This car has the on board computer which runs through the diagnostics sheck when you first turn the car on so you can't reset it by pressing on the gas pedal a few times like on the older models.
Can anyone help me with this?
Thank you in advance, I much appreciate your help.
Old 12-30-2003, 12:52 PM
pcv pcv is offline
Try this. Turn the ignition on, do not start the car. Pump the gas pedal three times within 5 seconds till the change oil light starts to flash. You might have to do it a couple of times to reset the light.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 12-30-2003, 04:47 PM
Re: Anyone know how to reset the change engine oil light to turn off
Good Luck.
THanks for your advice but I've already tried that and it doesn't work with the on board computer because when you turn the key on the car runs through it's diagnostics automatically and changes the screen.
Thanks again!
Old 12-30-2003, 05:06 PM
Impala boy Impala boy is offline
All you have to do is read your owners manual and it will tell you how to reset it .
Old 01-06-2004, 07:30 PM
ImpalaDriver372 ImpalaDriver372 is offline
Go into the vehicle settings with the radio controls. With the key turned to ACC, hold DISP on the radio for about 6 seconds and it should go into settings mode. Press DISP until you see oil life in all caps, then use Prev. & Next to scroll to reset oil life mon., then push DISP again. you should here a beep and the display should read Done. Scroll to Exit and press DISP again.
Old 04-15-2004, 10:10 AM
Maureen_KS Maureen_KS is offline
Send a message via Yahoo to Maureen_KS
Any guys in Kansas?
Hello
Any guys in Kansas?
Old 07-15-2004, 07:42 PM
youtink youtink is offline
oil change light
has to be reset through the radio
Old 09-22-2004, 11:34 PM
ryan2978 ryan2978 is offline
Send a message via Yahoo to ryan2978
how do you do it if you just have the regular radio with no disp. button?
How do I rewire my 1995 Magna so the lights turn off when the car turns off? Captain_Glen General Discussion 1 07-11-2010 06:55 PM
Help How Do You Reset The Service Engine Soon Light CADDY 97STS Seville 2 11-02-2005 07:36 PM
Change Oil Light Turn Off Tattoo1981 Grand AM 1 09-21-2004 01:06 PM
Anyone know how much the Celica GT-S engine weighs? Starbucks Celica 0 02-12-2004 06:00 PM
Anyone know how much the Supra engines weigh? need2know General 0 11-19-2003 05:00 AM
