Old 07-04-2012, 03:37 AM
whitelightning97 whitelightning97 is offline
0300, 1153, and 0141 codes for 97 RS 3.8l
my 97 camaro was running rough, rough idle, and rough acceleration and i thought it was due to the leak in my intake gasket but i took it to autozone anyway and it threw codes 0300, 1153, and 0141 which i found to be random misfire and two different o2 sensors. well before i could get it fixed, the problem went away. a few weeks later, i went out to my car to leave and it wouldn't start. i finally got it to start by giving it some gas but it dies the second i take my foot of the gas. would the bad o2 sensors cause it to do that and is it intake gasket leak related? ive never had this issue so i dont know what to do. please help me help my baby
Old 07-04-2012, 11:22 AM
Tech II Tech II is offline
Re: 0300, 1153, and 0141 codes for 97 RS 3.8l
Did you clear the codes, and did they come back?
The first code was a misfire...does the car misfire under a load?
Second code is for the heater circuit to the O2 sensor after the cat...which means it's taking longer for the O2 sensor to transmit data because it is not heating up fast enough...
The third code, is for the O2 sensor before the cat, coming out of the even numbered cylinders.....
Why do you think, you have an intake leak?
Also, are you losing coolant?
When the car won't start, disconnect the MAF sensor and see if it will start.....
Also check the vac line to the f/p regulator for fuel....
Another possibility is the IAC is not working properly, or the pintle and passageway is gummed uip, and the throttle plate and bore could be gummed up, too....
Engine sputters and stalls - '95 Transport 3.8L More Details Inside. yellowfiero Trans Sport 3 06-01-2008 10:09 AM
Opinions of value for private sale after new tranny and engine - 1995 Windstar 3.8L searcherrr Windstar 8 11-12-2007 09:51 AM
Intermitant CEL P1538 IMRC code. ’98 3.8L atikovi Windstar 1 01-14-2007 09:14 PM
exhaust questions for 3.8L 91 custom escort_jay102 Regal 7 04-25-2006 08:51 AM
Car shuts off and will not start - 3.8L sbjnmo Grand Prix 3 06-29-2004 01:41 PM
