Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 07-01-2012, 11:23 PM
mark1950m mark1950m is offline
1985 Riv w/307
Hi,
This '85 Riv with a 307 Carburated Olds runs rough after first starting (a cold start) in a hot (Texas) ambient temp of 85 degrees F and above. After reaching operating temp it runs fine. Everything appears to be okay except for this.
Any suggestions are appreciated.
Thanks, Mark
Old 07-02-2012, 07:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 1985 Riv w/307
Most common issue with these symptoms was the choke pull off on Quadjet, when it quits the choke stays shut too far and loads up the engine.. Air cleaner off, make sure the choke is closed when setting the throttle, just after start it should pull open about 1/8-1/4 inch if the pull off is working.
1985 monte carlo Dieing out eaglei022 Monte Carlo 8 11-09-2009 08:18 PM
leaking coolant 1985 Buick Riviera 307 5.0 V8 ayewhynot Riviera 2 06-11-2006 06:30 PM
'96 Riv Electrical Diagram? Even better.... 96 Riv Repair Manual? - Cannot find. alkemist Riviera 4 04-12-2006 10:05 PM
1985 Or 1985 1/2? IFIXTRUKS 924/944/968 4 07-01-2005 04:10 AM
1985 Riv torsion bars jase386 Riviera 1 11-25-2004 02:49 PM
