Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-27-2012, 09:07 PM
DaChevyClassic DaChevyClassic is offline
Motor turn over too before it crank,
94 Chevy Caprice. LT1 turn over too long before it crank. The motor turn over like 3 or 4 seconds before it fire up. What's the problem?
Old 06-27-2012, 11:35 PM
96capricemgr 96capricemgr is offline
Re: Motor turn over too before it crank,
I would put a fuel pressure gauge on it to see how long it is taking to prime and if it holds a prime.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 06-28-2012, 01:04 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
^This. Check your fuel filter.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-31-2012, 10:20 PM
I change the fuel filter. It still doing the same thing.
Old 07-31-2012, 11:16 PM
silicon212's Avatar
Confoundingly Lucid
Did you put a fuel pressure gauge onto the diagnostic port, as 96capricemgr asked above? If so, what pressure reading did you get?
Old 08-01-2012, 08:54 AM
j cAT j cAT is offline
if this occurs with a hot/cold start I would look at the voltage to the fuel pump at the rear of the vehicle with the pump running.
this could be an electrical / voltage drop issue if the fuel pump pressure is slow to rise or is a little low.
the pressure need be above 43psi. key on eng off and should hold for a few minutes.
some have found fuel pump wiring/connectors as the issue. inside the trunk is just one of them that for some reasons burns up.
problem with motor turning over and cranking midblu Problem Diagnosis 3 05-11-2010 07:49 PM
98 Isuzu Hombre turns over but doesn't crank 69 442 Hombre 3 01-06-2010 08:42 AM
new motor turns over, but won't start!! hondaboy16v Cavalier 2 02-16-2007 11:18 AM
Starting problem??? Turns over too much M72C75T99 Grand National/GNX 2 08-30-2005 01:27 PM
motor turns over fast won't crank gaowner1960 Grand AM 2 08-17-2004 11:21 PM
