Old 06-19-2012, 12:52 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Hesitant acceleration persists
Ok folks here it goes. 1997 Pontiac Grand Prix, GT N/A 160,000....About three months ago, I started getting a misfire intermediately on my number one cylinder and started getting hesitant acceleration. Here is what I have replaced so far. New aftermarket Cat. New AC/Delco 41-401 Iridium spark plugs with AC/Delco wires. Cleaned all my sensors with the appropriate cleaner, checked my fuel pressure and was within specs. Had my coil packs tested and well within range. Cleaned my throttle body, "was clean to begin with". Unplugged my MAF and problem persists. Replaced PCV valve and air filter. I don't know where to turn next besides have my local dealership take a look at it. Yesterday I sea foamed my air intake and that seemed to straighten it out for a while but today the hesitant acceleration persists. Idle is strong and when I get to cruising speed it runs like brand new. The only thing else I can think of is maybe a stuck TCC? RPM's are where they're supposed to be with no problem with overdrive. I did take it to a local trans shop and they mentioned the TCC was sticking but according to my Tach, it has not been happening lately... Any ideas? Much appreciated!
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 06-19-2012, 03:42 PM
Tech II Tech II is offline
Re: Hesitant acceleration persists
OK, new plugs and wires.....you say coils were within range....do you mean resistance wise? You should do a coil output test with a spark test.....
If ok, then have you checked compression? Does this happpen at idle or when under a load?
If at Idle, I would check valve springs, for a broken spring.....
If ok, could be an injector problem.....
Assume 3.8.....losing coolant?
Old 06-19-2012, 03:44 PM
Not losing coolant. I replaced both upper and lower intake gaskets a few years ago. I just now got a code PO121 so I'm going to clean my TPS with throttle body cleaner? In any event I have a new one on it's way from Rock Auto
4 door sedan
No Mods
Old 06-26-2012, 07:38 AM
Ordered a new OEM TPS and problem seems to be corrected.
4 door sedan
No Mods
'02 Outback Hesitation on acceleration ecamc Outback 2 12-21-2010 11:05 AM
E150 XLT Power Hesitation During Acceleration! leroge Econoline 2 02-28-2010 08:46 PM
slow idle/ hesitant acceleration dltbird96 Thunderbird 4 02-22-2005 06:47 PM
04 XLT Hesitation / Accelerator Delay 04BlueXLT Explorer | Explorer Sport Trac 6 11-10-2004 08:22 PM
Hesitation/acceleration problem-Please help! star13 Escort 2 11-21-2003 12:01 AM
