Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 06-19-2012, 07:41 AM
djvsmarkviii's Avatar
djvsmarkviii djvsmarkviii is offline
Starter shim size?
I'm putting a new starter into a 84 Iron duke.
The starter I pull out was not original and it had a shim with it.
I have an AC Delco that I'm putting into it and it did not come with any shims.
Do I need any with this new starter?
Old 06-19-2012, 02:17 PM
Tech II Tech II is offline
Re: Starter shim size?
As a general rule, you use the shim that is in the vehicle......for example, whoever put the new starter in, may have reused the original shim......
Start it and listen for a noise.....if if starts ok, but when you release the key there is a noise as the starter disengages, then the shim is too thick(not enough clearance,starter drive hangs up instead of easily releasing)....if there is a noise as it engages, then the gap is too big and you need a thicker shim......did you check under the flap of the box? They usually come with shims......
Starter Shims 89 Wrangler chief2000 Wrangler 4 03-23-2016 11:37 AM
starter shims sassygrass Silverado 3 07-04-2009 09:14 PM
Starter Shims jordan6543 Trooper | SLX | Bighorn | Wizard 3 09-11-2006 06:05 AM
rb25det STarter question, need starter ASAP rice_bo1 Technical 0 04-09-2006 04:27 PM
starter bolt size yooperlou Wrangler 2 11-10-2005 10:09 PM
Tags
shim , starter
