Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 09-06-2006, 06:14 PM
jordan6543 jordan6543 is offline
Starter Shims
I just had my starter replaced, but now it makes a high pitched whinning sound when it starts. So I was told that putting in shims would stop this sound. But will it do any damage if i dont put the shims in? Any input would be really apperciated.
Thanks Jordan
1993 Trooper S
Old 09-07-2006, 05:12 AM
atfdmike's Avatar
atfdmike atfdmike is offline
Re: Starter Shims
You definitely want to shim the starter. The sound you are hearing is the starter motor over revving due to the bendix gear being held in the flywheel gear by pressure from the gears being too tight. When the engine starts the flywheel begins spinnig much faster than the starter motor is designed to spin, hence the sound you hear. The shim moves the starter away from the flywheel enough to allow the starter to disengage once the engine starts and you release the key.
If you don't get it fixed, the starter motor will be damaged and you could also damage the flywheel gear if the starter gear freezes due to the failure of the starter motor to disengage.
This will not get better with usage, although you might notice a change in sound.
I'm not a pro, but I do know this!
Old 09-08-2006, 07:06 PM
Re: Starter Shims
So got the same shop to put the shims in the next day, but my girlfriend had been running around town with the starter installed wrong the day before. When i went to pick up the trooper he told me that the ring gear is missing a tooth. Which is why it still makes that high pitched sound. The starter i had before never made this sound. So do you think that the shop damaged the ring gear when they installed the new starter or by them giving it back to me with the starter installed wrong?
1993 Trooper S
Old 09-11-2006, 06:05 AM
atfdmike's Avatar
Re: Starter Shims
Hi, based on what you report, which seems to be that the starter continues to make a noise AFTER you release the key when the engine starts, the continued noise from the starter may be due to it having already been damaged by the improper installation, or the mechanic still has not shimmed it properly and it continues to hang up.
As for the missing flywheel tooth, that would NOT be the reason for the noise from the starter, as it would more likely let the starter gear release rather than hold it in. A missing tooth is not necessarily a disaster unless the starter attempts to engage at the broken tooth, in which case it may not be able to, depending on how much of the tooth is gone. So what you end up with is that the engine may not start since the starter cannot engage what is not there, or that while cranking, the starter may disengage at that point, depending on remaining material of tooth on flywheel and condition of adjacent teeth.
If you never had a problem with starting and now you do, I suppose you could argue that the damage was done by the new starter. I think the mechanic will argue with you that it was preexisting, mainly because it is a big job to replace the flywheel gear.
A good mechanic should be able to recognise the starter hanging up and install the proper amount of shims , and I have to wonder why he did not in the first place.
The amount of shims can vary in order to make for the proper alignment, and sometimes it is the difference of a few thousandth of an inch between proper lash and hanging up. Although shimming is not mentioned in the following articles, it is a generally accepted practice with this starter design.
1993 Isuzu Truck Trooper (4 Door) V6-3165cc 3.2L DOHC (6VD1)
Vehicle Level Starting and Charging Starting System Description and Operation Description and OperationThe starting motor has field coils mounted in the starting motor (yoke) frame. The magnetic switch assembly and the parts in the starting motor are enclosed in housings so that they will be protected from dirt and water. In the circuit, the magnetic (motor) switch coils are magnetized when the ignition switch is closed. The resulting plunger and pinion clutch movement causes the pinion to engage the flywheel gear and the magnetic switch main contacts to close, allowing cranking to take place. When the engine starts, the pinion overrunning clutch protects the armature from excessive speed until the switch is opened, at which time the pinion will disengage.
Vehicle Level Starting and Charging Starting System Testing and Inspection Pinion Gear Does Not Properly Engage Ring Gear Pinion Gear Does Not Properly Engage Ring GearTesting and Inspection Fig. 1 Pinion Gear-ring Engagement Is Improper.
I hope this info helps give you some frame of reference. Good luck.
