Old 06-18-2012, 04:03 PM
buffercat buffercat is offline
High idle
When I first start warm or cold the idle is approx 1300rpm and the car will go by itself at approx 25 kph. This will be ok after about 2 min of driving and all is good. What am I missing some kind of idle sensor ????
Old 06-18-2012, 09:05 PM
danielsatur danielsatur is offline
Re: High idle
1) Clean Incoming Air Control (IAC).
Is the Check Engine Light on (CEL) ?
What's the <year> <mileage>?
Also look @ Similar threads @ the bottom of yours.
Old 06-19-2012, 05:30 AM
Re: High idle
Mileage is 145000 kms no engine light and its a 2002 lesabre 3.8, I'll check the IAC.
Old 06-19-2012, 06:26 AM
Tech II Tech II is offline
Re: High idle
In addition to pulling the IAC and cleaning the pintle and mating bore, clean the throttle plate and bore also...it's possible the throttle plate could be hanging up in the bore......
Also check for possible vac leaks......
2001 Pontiac Grand Am: high idle, high rpm shifting gustie07 Grand AM 16 01-17-2015 02:56 AM
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 11:46 AM
94 cutlass 3.1 high idle gc9150 Cutlass Series 0 06-21-2011 05:51 PM
High Idle with New IACV - E150 XLT leroge Econoline 0 01-15-2011 05:21 PM
1988 cherokee 4.0L hgih idle/engine tick pstoric83 Cherokee 9 08-05-2009 11:18 PM
