Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-21-2011, 05:51 PM
gc9150 gc9150 is offline
94 cutlass 3.1 high idle
Hello,
My 94 cutlass 3.1 was idling @ 2,000rpms, and i have done the following:
checked everywhere for vacuum leaks, none found
replaced iac (original was stuck)
replaced tps (original was @ 2% even with my foot off gas)
replaced iat sensor (this brought idle down to 1500)
now the idle is down to about 1500, but still no success. Any ideas?
It ran fine until i removed the upper plenum to replace a bad fuel injector o-ring. When i put it back together i had a check engine light showing the throttle position sensor was low.
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
94 Skylark 3.1 high idle on cold start majic723 Skylark 2 03-31-2008 03:06 PM
3.1 high idle, runs rough zandor Regal 2 07-10-2004 03:59 PM
93 cutlass 3.1 odd idle problems censlow Cutlass Series 1 09-19-2003 10:51 AM
Tags
cutlass , high , idle
