Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 06-13-2012, 10:08 PM
BLACKANGEL32076's Avatar
BLACKANGEL32076 BLACKANGEL32076 is offline
how to check voltage on 1998 ES300 EGR Position Sensor
I have a Lexus ES300 wtih the 3.0L V6 with 136K miles. It has a new battery and alterantor. How and where do I check the voltage on the EGR Position Sensor and/or related relay? DON'T tell me to check google, it has failed me in this search. I have an intermitant check engine light coming on with a p1410 code comeing on. When I check the voltage at the sensor (brown wire) I only get 4.9 volts. When I remove the sensor from the EGR assembly, I have no movement on the solenoid/sensor the small plunger doesn't move when the acc, on , started positions on the ignition. I'm wondering how to test the properly and/or replacing it. Thank you for any help given.
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
EGR Position Sensor? Smokefan20 Problem Diagnosis 1 10-04-2008 01:28 PM
1998 RAV4 Cam position sensor KenwoodTurboGTA RAV4 1 08-12-2004 08:55 PM
1998 Rodeo Crankshaft position sensor Ron Miller Rodeo | Passport | MU 4 10-30-2003 08:25 PM
