Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-29-2003, 03:41 PM
Ron Miller Ron Miller is offline
1998 Rodeo Crankshaft position sensor
I have an OBD II Auto Scanner and am getting code P0342 which is the crankshaft position sensor. Does anyone know where this is located on a 1998 Rodeo? I have the 2.2L 4 cylinder. There is no repair manual for this model. Thanks.
Old 10-29-2003, 03:47 PM
rodeo02 rodeo02 is offline
Ron, check this post: http://www.automotiveforums.com/vbul...d.php?t=146198
G/luck
Joel
Old 10-29-2003, 08:52 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
P0342 is not a CKP code it is CMP=cam position sensor
you can replace it but you will need your local dealer to run a learn procedure on it or you check engine light will come back on
Old 10-30-2003, 07:45 AM
Screwtape Screwtape is offline
Crankshaft Position Sensor is right behind the alternator, if you peek between the alternator and the engine you should be able to see the wires, and the camshaft position sensor is in that black box in front of the engine with the yellow mark on it. If you take the little black plate off that covers the spark plugs you can see the wires for the sensor going into that black box.
Old 10-30-2003, 08:25 PM
Lightbulb
(Isuzu TECH) crank sensor is located on the pass side of the block and gets its reading from the crank shaft hence the term crank sensor Camshaft posotion sensor is located behind the timing cover right between the two camshaft sprockets which is where the CMP sensor gets its reading
Crankshaft position sensor GregGP Grand Prix 1 03-25-2010 04:33 PM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
crankshaft position sensor on 99 isuzu rodeo zolo6321 Rodeo | Passport | MU 1 01-03-2009 12:26 AM
Isuzu Rodeo 1999 - DTC 0336 Crankshaft Position Sensor IsuRod1999 Rodeo | Passport | MU 5 05-27-2007 03:16 PM
1998 Taurus Crankshaft Angle Sensor / Synchro / Cam Position Sensor rjs985 Taurus | Taurus Wagon 9 02-12-2007 04:46 PM
