Old 06-11-2012, 12:08 PM
Boost1egt's Avatar
Boost1egt Boost1egt is offline
95 7.3 powerstroke hrd start
I have a hard start condition on a 95 f250 with the 7.3 powerstroke. It starts until the engine oil pressure goes up while cranking. I thought the high pressure oil pump was bad, so a replaced it with a known good one. But it still does the same thing. Glow plug system is working fine. Have rpm signal. The high pressure oill reservoir is always full. The engine cranks and doesnt start until you see the oil pressure gauge go up. Any Ideas???
Old 06-12-2012, 09:04 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 95 7.3 powerstroke hrd start
PM sent !
" Sometimes I grow so tired "
Old 06-13-2012, 03:18 AM
moparmikefloyd moparmikefloyd is offline
i recently fixed one, it was the plastic fuel drain valve on the backside of the fuel filter, it was not leaking fuel out but sucking air into the system. replaced it, fired right up
7.3 powerstroke dies at random.... FastTeen F Series 2 07-30-2009 10:36 PM
94 7.3 e350 no start jamarg E Series 1 08-05-2008 06:18 PM
2002, F-250, 7.3 Powerstroke High Idle dman504 F Series 1 02-12-2006 05:53 PM
7.3 Powerstroke 4x4 X 18.5mpg down to 16 now? Pat_96 Excursion 3 01-14-2005 08:55 PM
01 7.3 Powerstroke smokes deerehunters F Series 3 12-02-2004 11:12 PM
