Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 06-08-2012, 09:15 PM
VividVisions VividVisions is offline
how do i remove crank pulley to replace timing belt 2.0
Why am I breaking tools?? What am I doing wrong, am I suppose to get the bolts red hot n remove em?? I haven't had good luck with allen heads not rounding out, am I suppose to remove the big bolt?? Any help would be appreciated
Old 06-08-2012, 10:02 PM
FishFind FishFind is offline
One Hot Shot
Re: how do i remove crank pulley to replace timing belt 2.0
I know nothing about this car but most of the time you need a puller to remove. Call a auto parts store and see if they have one you can rent.
Yes the big bolt in the middle needs to come off. It is best to use a impact gun to remove it. There is a tool that will hold the pully in place when you take the nut off. FYI take off the ignition coil before you start the car on accident.
Also a Haynes repair manual may be worth the $30 in your case. It will give you many details including torque and all the things that you will need to know.
Old 06-09-2012, 04:34 AM
Well.... it seems like I don't have to remove the big bolt, common sense tells me that the 4 allen head bolts connect tell serpentine belt pulley to the timing belt gear, which the gear is held on by the big bolt. And I wanna stay away from putting any heat to it because there has to be a seal right there n heat n seals don't mix.
Old 06-14-2012, 06:28 PM
culliphj culliphj is offline
i guess you have already got bolts out
if not,,grind the heads off
you can use a pair of pleirs to remove the remaing studs
Old 06-25-2012, 08:02 AM
I ended up using 2 10mm studs (lower engine studs from type 1 beetle) and a flat piece of stock with a M4 bolt to hold the crank pulley, and I ended up hammering a T40 hex bit in the SHCS (Socket Head Cap Screw) n got 2 of them out, got one out with a T45 n then last one T50. Also made the tensioner tool out of the same pics of flat stock, if I ever get time I will post pictures n measurements of the tool.
2.0 z-tech timing belt , no timing marks ocrank pulley 67VETT Contour 2 03-19-2008 09:00 PM
Accesory belt Replacement on 98 2.0,,AAARG!!!!! ITFD Contour 4 02-12-2006 08:40 PM
Timing belt replace/97 Accord 2.2 davidm5377 Accord/TSX/Accord Hybrid 6 02-16-2005 11:43 PM
Replacing outer crank seal & Timing Belt.... vassil3427 Lumina 1 07-03-2003 08:39 PM
